drifts14x »
https://forums.nicoclub.com/drifts14x-u5875.html
Thu Aug 19, 2004 9:38 am
Hey there, I found a list of parts from a fellow NICO member on the boards who wrote up a pretty complete list of parts for a $1000 turbo setup (the basis of which I'm following). I have made some notes on the list, but here it is...
200 @ the flywheel??Turbo Project:
Oil Path: Cost--------------------------------------------------------1/8" BSPT hex nipple: = $2.50Female T: 1/8" Brass BSPTxBSPT = $3.50 Brass Adapter: 1/8" Male BSPT to 1/8" Male NPT = $5.00 Coupling: 1/8" Female NPT to Female NPT = $2.00Braided Hose: 3/16" Hose ID, 1/8" male ends = $11.00Needle Valve Fem In/Out 1/8" Brass NPT x NPT = $10.00 90deg Male Elbow: 1/8" Alum NPT x NPT = $6.00 Adapter to turbo housing = $2Oil Drain hose: 3/4" = $5Oil Drain fitting: 3/4" ID Nipple = $2--------------------------------------------------------Total = $49
Exhaust Path: Cost--------------------------------------------------------Turbo manifold = $200 ($250 on eBay)Turbine machining = $0Turbine housing = $150 (T3 from Saab 9000 or Volvo 740/240)Turbine rebuild kit = $100 ($60 on eBay)Turbine to downpipe flange = $5Downpipe 90 deg 2.5" pipe bend = $10Downpipe welding = $50O2 bung = $10New O2 sensor = $30 (N/A)New O2 = $20EGR pipe = blocked Downpipe to cat flange = $10Heat wrap = $25 (Not Necessary)--------------------------------------------------------Total = $610
Intake Path: Cost--------------------------------------------------------Intake filter = $20 (Done)3" PVC MAF = $2 (N/A)3" flexi intake hose = $10 3" to 2.25" adapter = SiliconeTurbo Compressor = (from exhaust side)2" pipe from compressor to SMIC = $101g DSM side mount intercooler = $30 (or RX-7 Top-Mount, Saab, etc)2.5" pipe from SMIC to throttle body = $152" Nitrile Hose = $102.5" Nitrile Hose = $15Heat spray = $10--------------------------------------------------------Total = $122
Misc:--------------------------------------------------------370cc fuel injectors x 4 including s/h = $75 Autometer Boost Gauge = $30Autometer Fuel Gauge = $30Autometer A/F Meter = $50
Oil for swap: 8 quarts Valvoline durablend = $20JB Weld = $5--------------------------------------------------------Total = $215
----------------------------------------------------------------------------------------------------------------GRAND TOTAL = $996
Now, Can anybody think of anything CRITICAL that I'll need, or things that I can drop. I am strongly considering a T3 for creating between 6-10 PSI. I appreciate the help.
