what else do i have to get with this ~~HKS Lash Killer Kit - S13/S14/S15 SR20~~
eclipse069906
do i need anything else to make this work and what all does it come with anyone have it
thang nguyen
Car: 1989 Nissan 240SX Fastback
Um from what I understand, you will probably need shims and guides for it to fit and perform properly. And the kit isn't needed unless you plan on reving your motor to 8K or more.
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Mazworks sells the HKS Kit and they told me it includes shim and all. Send them an email to find out.
USsil80
the obvious solid-type camshafts... the tool the measures the gap between the lifter and the shim so you can set the gap easily because you will be doing it it alot at first... some nice valve springs so you can rev that girl out to where you need that solid lifter kit
