nwmrkt wrote: ah yes, nice thanks. Would you mind pasting your full suspension mod list? Sounds like your going all out and i would like to see what your doing so i can plan my stuff out too. thanks!
I already basically mentioned it but okay...
It's a 91 S13 hatchback
-Front and Rear DC Sports CS-2 STBs.-All whiteline polyurethane bushings on everything-New front LCA with white polyurethane bushings-New hard race endlinks with whiteline polyurethane bushings-HICAS front rack and rear swaybar-Whiteline subframe polyurethane spacers (sucks, i want to replace the full bushing with solid alum)-Nismo Power Brace-Yashio Factory tension rod/brace to subframe brace-Yanack steering rack metal bushings-FR Sport steering column metal bushing-KYB AGX + Stech springs front 4/4 setting dampening rear 8/8 setting dampening-Fully stripped car except dash and door sides, other weight shedding too such as no A/C, no cruise control (wiring, unit and computer taken out), no front bumper support, no radio/cd, no speakers, No HICAS (computer, electronics everything), HICAS eliminator (i want a hicasless subframe though) soon i want to remove the heater unit too, some other stuff too.-Moog inner and outer s14 tie rods. (sucks, waste, unadjustable 'heavy duty' oem replacment, can not take abuse of uprated suspension/racing).-5 lug conversion front and rear
That's I think all, not sure.
The next on the list right now is to get SPL pro inner and outer z32 tie rods, SPL fender brace (unles there's a lighter/stronger/better one), and SPL pillowball TC rods. As well as rear wheel bearings as I need them, the 300zx ones are worn out as they are the same ones I got when I did the 5 lug conversion. This is all I'll most likely do before the car gets stored for the winter/salt season hah.
Next it's largus front and rear swaybars, all rear pillowball SPL arms, Non-hicas subframe reinforced... I need/want a stronger subframe, alum bushings.
Then after that get koni shock/coilover combo. Oh and I suppose the c-pillar bar is one thing I'm forgetting.
Ultimately also stitch welding and cage... but that'll be last. Maybe the stiffening foam.
More weight shedding... fenders, bumpers, hood and lexan windows. Some other weight shedding under hood and inside.
That's pretty much how things are sorted so far... and my line of thinking of what I will do next after each thing.
Also ultimately functional wing front and rear... underbody front and rear + diffuser... i have some serious plans... hehe.
I am also curious on steering quickeners... i have yet to drive a car with one... that might help, as i dont like to turn my car's wheel so many times.... i've considered aftermarket steering wheels too but i dont know...
I really want to go all out and hardcore on this car...
Modified by a_ahmed at 12:26 PM 8/23/2007
