defrag010 wrote:I've been reading around here for a while, because I bought a wrecked Q45 as a donor swap car for my rx-7.
I had planned on yanking the engine/transmission/wiring harness/ecu to install in my rx7, but the more I read about all these electronic functions the more I'm getting worried.
Here are a few of the main things that I'm worried about:-Is the Engine/transmission harness separate from the chassis harness?-What exactly does the FPCM do? and is the fuel tank temp sensor important?-Will the ECU trip a code if all of the EGR stuff is gone?
Basically, I'm doing a minimalist install, and I'm trying to figure out the barebones necessities for the engine to run and funciton properly.
Also, how hard would it be to convert the fuel injetors to top-feed style?
Is there anyone that makes a OBD-1 datalogging interface so I can scan codes?
Starting from the beginning:1. The engine/ECU harness is "somewhat" separate. You can take them apart but there are shared connectors.
2. The FPCM controls the fuel pump speed. There are three steps: Hi, Med, Lo. You can run the fuel pump off the ECU's fuel pump relay output with no problems. The FPCM mainly reduces fuel pump noise at cruise, and increases fuel pump life.
3. If the ECU is from a Federal (non CA) car, it will not trip a code. If it is CA, it may trip one.
4. Injectors you're on your own - I don't think anyone has done it. Call RC engineering in CA and ask them for advice.
5. There are a number of Consult interfaces (Nissan's name for the OBD interface) available, including one that I make.
If you are using the Q engine in a different chassis, some people (including myself) can reprogram your ECU to ignore the EGR, carbon canister, FPCM and anything else you want. Email me if you're interested.
