what ECU works with redtop?
deCksy
so i got a good deal off a redtop but it didnt come with an ECU and i'm having a hard time finding a #62 ecu. so i'm wondering what other ecu will work with my manual sr redtop. thanks
oh yeah i searched already but couldnt find a straight answer.
biglipzit
Car: sr20det S13 RHD 200SX
zerothread?id=59346
Years-S13 red tops: 91-94S13 black tops: Late 94-98S14 notch tops: 95-98S15 notch tops: 99-01
Alas, the changes/advantages of the s13 Blacktop:*
-Newer-Usually lower mileage-Usually about $500 more expensive (because its newer)-Minor ECU changes 96-98 (interchangeable with all s13 ECU’s) -Minor wire harness changes-Larger Oxygen Sensor (still narrow band, no performance gain)
10 lines below the picture... Someone correct me if i am wrong but in the sticky it says that the ECU is interchangeable with all other S13 ecu's...
Henry G
62 redtop manual63 redtop automatic
both work
SR20DETpwr
Car: 1992 240sx SE w/ built sr20det redtop
motor built by Stewart Engines LLC
put together and tuned by ILL Garage
.86 GT2871R @18.5psi = 393.4whp
If you have a manual sr20det redtop (as I would assume you do) the #62 ECU is the only one that will work with your motor [URL]http://www.store.yahoo.com/pha....html - they sell used #62 ECU's for your motor (excellent company to do business w/ I buy a lot of my stuff through them).
Titanium
SR20DETpwr wrote:If you have a manual sr20det redtop (as I would assume you do) the #62 ECU is the only one that will work with your motor [URL]http://www.store.yahoo.com/pha....html - they sell used #62 ECU's for your motor (excellent company to do business w/ I buy a lot of my stuff through them).
Both 62 and 63 ecus work. Not only 62.
