xjon »
https://forums.nicoclub.com/xjon-u1094.html
Wed Jan 28, 2004 1:29 pm
comparing the r33 wiring diagram with the ka wiring diagram (fsm). On the KA, there is a wire (g/y) going to the rear window defogger relay (it's on the brown plug step#3). Does anybody have a working defogger, or what wire should I splice this into? this wire leads back to the KA ecu pin #44
Also from that brown plug, the l/g wire goes to the "thermo control amplifier" which I believe is the temperature controls on the center console. Does this not work after the swap also? BTW this wire leads back to the KA ecu pin #41.
I believe the heads up display with the electronic speedo will work in my case. Does anybody have this not working after the 8 step with electronic speedo and HUD.
Also in addition to the 8 step, my speculation is to attach pin #32 from the RB ecu which is the r/w wire from the white plug to the r wire from the KA brown plug in step #3. I believe this will work the check engine light on the dash. Please tell me if I'm doing something unnecessary. Will the check engine light work anyways if I don't do this?
What I'm trying to do here is to figure out what wires I can plug/splice together at one time during the install so I don't have to keep going back and forth peeling electrical tape over and over again.
thanksBTW I have a typeI RB25 with megala.com ecu info, going into 93 240 with fsm ecu wiring diagram.
