what does your stock rb25 run??
xricanpapitox
Car: 1998 nissan 240sx / 1993 mazda rx7
i just finished my rb25 s2 swap...was just wondering what to expect 2 see on my timeslip when i run the track
outlaw020991
Car: 1995 s14 RB25DET
expect to see high 13's on a damn good run
low 14's for an amature
but at the end of the day it's about the fun you had, and even if there is a 12 sec honda that woops your a**, at least you know yours sounds better!!!!
db_s13
Car: 92 VQ30DET 240sx
i run a 13.7 with a stock rb20 in a s13, so i would think a rb25 s14 would be able to run a mid to low 13
Thanielson
Car: 95 240sx neo rb25det
for the most part mine is a stock rb25 just full downpipe back running at 10psi and no air filter ran a 13.4 at 106 only ran 2 times that night first was 14.1 at 109. i was told that night that the track was realy realy bad to they had scraped all the rubber off the track from the previous year so it was bare asphalt.
Modified by Thanielson at 12:55 PM 5/2/2009
mean240
Car: 240sx,crx
Thanielson wrote:for the most part mine is a stock rb25 just full downpipe back running at 10psi and no air filter ran a 13.4 at 106 only ran 2 times that night first was 14.1 at 109. i was told that night that the track was realy realy bad to they had scraped all the rubber off the track from the previous yesr so it was bare asphalt
down pipe with divorced waste gate, full exhaust no cat plus resonator, intake. 10 psi
2 runs = 15 flat. my last run 14.9 18 inch wheels and i chocked a little!
and i have a bigger body than a s14
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
Mickey Thomson Drag slicks on a stock RB20, a local guy ran a 13.1. Never go to the track looking for the best results on street tires, its a waste of time.
You need to learn how to launch the car if you're running anything slower Than a 13.5. There's no reason you should run that slow with a 25. //No offense to anyone here//
I just cant imagine why you'd run ANYTHING but slicks at a drag strip. Also putting on stock rear suspension and removing you stock front sway bar helps you get out of the hole better.
ANVIL
Car: RB25DET S13.5
ran 13.2@108 stock motor, on street tires, no lsd, 12psi, 90octane gas
i run mine w/o slicks because i like to see how my dd setup goes vs peoples "track setups"
once everything gets sorted out with my new setup... hunting for mid 11s... and hoping to get banned from the track (11.5 or faster w no cage)
Modified by ANVIL at 10:03 AM 5/3/2009
stevespeed
Car: RB-Swapped S13, FTW
ANVIL wrote:ran 13.2@108 stock motor, on street tires, no lsd, 12psi, 90octane gas
This dude can drive, that good of a time without a diff!
ANVIL
Car: RB25DET S13.5
it was kinda too easy. without proper tires or an lsd no matter how i launched it i would always get 2.0 on the 60ft. i figure lsd and a better tires on that setup would easily be 12s so im thinking 11s shouldnt be out of the question on my new setup
stevespeed
what size rear tires are you running?
Also what RPM are you launching at?
Got any dyno sheets of your setup?
ANVIL
Car: RB25DET S13.5
me?
the rear tires were 205/50/15s on that setup.
got new wheels and tires this year though, going to be using a set of bfg drag rads 275/50/17 (i think, i dont remember 100%, but i know they are 275 r17)
i dont remember exactly where i was launching at but i did quite a few passes and i think 3.5k-5.5k yielded the same 60's even though they felt different coming out of the hole. i think i was doing mostly 5k launches
oh and heres my dyno sheet of that setup
stevespeed
you got a front mount? or running side mount?
sorry for all the questions I am trying to get a feel for what mine is gona run and put down
AZ89two4Tsx
Woah ANVIL, they have racetracks in Alaska? Really?
Sil240
Car: Nissan S13 "The One Cam Wonder"
Yeah thats a good question....Well they get half a year of good weather or something like that right?
Life in Alaska must weird, i dunno If I could sleep with the sun up regularly.
Running 266whp, he's definetly not running a stock sidemount.
stevespeed
I guess the Alaska part solves that mystery.
I am still wondering how you got a 13.2 on 205's
You either have some damn sticky tires, or an AMAZING driver.
I broke my 245 Soft compound Kuhmo's free with my KA
toadx8u
Car: 1975 Datsun 710(coming soon F20C)
1993 240sx Vert DD
1995 240sx GT3788 RB25DET
1996 240sx LSx 5.3L
2000 F-250 Crew Cab Diesel
2004 Honda RC51
i managed a 12.2 @ 112 with my stock setup...divored dump...full exhaust...front mount...boost controller 12psi...and 255/50/16 bfg drag radials on N/A z32 wheels...i was leaving the line at 5k...slip the clutch a lil and then dump...pulling 1.6 60's...made 312 on the dyno with the fact ecu
ANVIL
Car: RB25DET S13.5
FMICblitz ebc (12psi)Apex Power FC - had to get it tuned... the basemap dynoed only 185whp!
i wouldnt say im an amazing driver... i only managed 2.0 60 fts. i pretty much launch as toad describes... just slip it a lil til i get the feel that i can dump it. toads times and motor impresses me... its like a freak of nature... 12.2 and 312 out the box.... thats amazing! ill be happy to pull 1.8 60s. im sure ill do better with my bfg drag rads and the vlsd i got (still needs to be installed)
as for the Alaska questions LOLumm we get like 5 months of AWESOME weather sun up for over 14hrs a day. its really what keeps me here are the summers. winters are kinda depressing... but it gives me build time and time for snowboarding.
Thanielson
not trying to hyjack or anything but what would the round about good size be for a 300whp 250wtq for some mt et drag's
limitlesstuners
Car: 89 240 *RB*
I have a 89 Coupe with rb20, last trip to the track ran a 13.90 at 98mph with a 2.09 60ft.
Car is Stock RB with stock charger, no dyno results, I'm running a N62 maf with SAFC based out and Stock Tear drops on the rear with a VLSD. Boost was at 11psi and it felt like it was running out of breath
toadx8u
1993 240sx Vert DD
1996 240sx LSx 5.3L
2004 Honda RC51
yeah everyone agreed with that "freak" diagnosis when i started layin down times...the tires are what make the drag car...you just have to find the right tire pressure and suspension setup...speaking of which i found out today that HKS has discontinued the hipermax drag coils...im not happy about this at all...does anyone know another company that sells a similar set up? i just saved 5gs to buy 2 sets...
meet07
Car: 89 180sx rb25det
I ran a best of 13.4 last month at the track with shi**y 2.2-2.4 60ft times. Came back home and realized that I had 5 broken exhaust manifold studs. Able to fix all but one which is on runner 6(the leak was on runner 1...so its fixed) I was running 12lbs without my safc and 3" exhaust,no cat,17x9 mustang wheels(heavy) with 245's up front and 255's in the back,fmic,atmos bov,freddy intake manifold and q45 throttle body.
I put the afc on and fixed the exhaust manifold studs and she pulls much harder. I think I could run a 12.9 with stock suspension and 14lbs. I just got some subframe collars as well. Launching at anything over 2K she wouls spin and have sever wheel hop..
blurrbosi
Car: 240's
13.0 @ 112 2.2 60ft on stock RSX wheels with falken azenis spinning like a whore. Welded diff, stock turbo 10psi. 327whp at 12psi on my dynojet
toadx8u
1993 240sx Vert DD
1996 240sx LSx 5.3L
2004 Honda RC51
BHFR-GTR
Car: 1993 s13
man i have the same prob, i wanted the hypermax drags ( 750hp single turbo 26 s13) but cant get them i just oredered a set of fourtune auto drag spec coils i will let you know what the are like the spring rates are 3k and 5 k 5 k front and 3 k back with drag spec valving, veryy nicely priced at 1200 shipped, 50mm strut tube instead of the standard 40. if you are interested let me know, i know the people who make these
toadx8u
1993 240sx Vert DD
1996 240sx LSx 5.3L
2004 Honda RC51
mark you are the man...i had no clue that any other company was even makeing a drag coil....thank god someone still loves us....anyway im interested in 2 sets both for an s14...so do you think i can get a better deal since i want multiple sets... ...lol
im just so estatic right now cause of this...the only thing that blows is that if i order them now i wont get them for at least a year....since i leave wed for iraq...
