What does your 240 weigh?
lexcrob
Car: I get a different ride faster than I could update this.
92 base model
Removed: rear seats, seatbelts/carpet/spare tire etc./front bumper support (gone when i purchased)
2470lb's
Im trying to get it down to 2200 im jsut trying to fig. out next move weighing $ and functionallity!
I still have A/C,heat,radio -2 speakers and powersteering
The front seats are insane heavy any affordable replacement idea? or maybe lighten them?
Gutting door panel guts?
Getting lexan rear glass?
Driveshaft is next steel is only affordable option?
Anyone drilled out a rear bumper like honda guys do for drag? :wtf2:
NismoRTuneS13
Car: 1993 Nissan 240sx SE
Are you building a track car? For every 100ibs. removed you will only shave off 1/10 of a second from your qaurter mile time. I used to be obsessed with weight reduction too but realized that gutting your interior does nothing further than create a noisey cabin that gets alot hotter in the summer due to less insulation. The difference is not going to be seen or felt at all except for gas mileage. Hundreds of pounds will need to be shed in order to see any difference. And keep in mind too light of a car will be harder to control at high speeds. Your car is already light to begin with. I suggest focusing on building HP. A 300zx Twin Turbo 2 seater weighs 3,474ibs. and they rape.
corn322
Car: 1993 240sx
1993 Hatchback.
Removed: Rear seats, belts, trunk paneling, spare tire, A/C, radio, speakers, misc. brackets and bolts.
Replaced: Driveshaft, battery, flywheel.
About 2510lbs with no driver and no gas.
The front seats are insane heavy...
My S14 front seats weigh 30lbs each. I don't know what S13 seats weigh, can't be much more.
Steel is just the cheapest option. The aluminum one from shaftmasters only costs $46 more than their steel. I weighed the aluminum shaft at 10 lbs less than my stock driveshaft.
lexcrob
Eh if you jump on a weight to power time estimater it makes a big diff.
I know its hot cold loud its not the daily so thats fine in fact it will have a welded diff and wont be leaving town. Probly not even out in the rain unless i wana be easy on tires driftin.
^sounds like im doing pretty good ill see if i cant get it down enough i wanted to tube frame the front end guess thats pretty involved gotta read few books on it know how to weld GOOD and seems like it just be pitta
Im just trying to make it weigh bout much as a gocart throw on slicks and SPANK my brothers 16,000$ vett for under....well im at roughly 3000$ into it LOL WRENCHIN BRAGING RIGHTS
lexcrob
the pikes peak article car built a tube frame rear subframe!!!!!!!!!!!!!!!!!!
they need to make that for aftermarket*****
lexcrob
yes its a track car that ill be able to idle to tracks.....
