kdkrone »
https://forums.nicoclub.com/kdkrone-u9295.html
Wed Dec 23, 2009 8:11 pm
Damn, Heath, you caught me.... I made the mistake of not lifting the hood of the engine to see whether the fan was turning before I started that last post. I finally did this morning and, of course, it was, so I called and cancelled the started shipment. I had vaguely remembered a thread from a couple of years ago, so I searched and found it. Q45tech had referred to WOT, but someone else talked about depressing the gas peddle completely without pumping it. Lo and behold, it worked...
Jerry Tucker had told me many years ago about not driving the car short periods of time (less than enough to warm it up), and this last time, I parked the car after driving home from work, same as always (12 miles). I had left it sitting for a few days before trying to start it, when it just turned over with such a high pitch that I thought for certain it was spinning without engaging, which was not the case.... apparently either flooded or no compression... the WOT trick worked just fine...
