What does this connector attach to?
csem16
Was reinstalling the heat shield on the exhaust manifold after changing the o2 sensor and had to unplug/remove a few things to get it in. I cannot for the life of me figure out where this connector goes.
It's bundled with the connector to the o2 sensor and both wires thread into a plastic membrane in the wall of the engine compartment behind the driver's side headlight. It doesn't stretch any further than the distributor, so I think it goes somewhere in that area. This is a 1990 D21 4-cyl KA24E.
Any suggestions would be appreciated.
Thanks.
Modified by csem16 at 10:51 AM 9/8/2007[/i
bobzilla850
Car: 92 Hardbody
does your truck have a tach? if not than thats the plug for the stock hookup
csem16
Makes sense. I'll have a go at hooking it back up tomorrow. Thanks for taking the time to respond.
NM50
Car: 94 D21,98 03 hummer H2,66 311 CA18ET ROADSTER,94GEO METRO pimp mobile
It looks like the distributor ground.There should be a tab on the back of the distributor.
bobzilla850
Car: 92 Hardbody
notta a problem. my truck didnt come with a tach so after i found one in the garage i found that same wire not attached to anything, striped it, ran it to my cab, and viola! i have a tach
btw, why are these forums so slow?
