what does the stock turbo flange look like?
Trike
basically i want to know whether or not i can bolt my t3/t04e onto the stock turbo manifold on the sr20. goals would be about 300whp. what about downpipe issues?
Thanks
themadscientist
nope. The the CA and SR have a T25 type flange, it's rectangular but smaller. You can have a T3 flange welded onto the manifold to mount the turbo.
Trike
which would be cheaper? getting another manifold or getting it welded?
themadscientist
Turbonetics sells the T3 flange for I think $30.00 and whatever a muffler shop would charge you to weld in onto your manifold. It's cheaper than a new manifold.
Trike
what about the downpipe? stock downpipe still fit?
themadscientist
it should but the outlet of the turbo you use will determine that.
GraySilvia
Car: auto-x, drag racing, beer
the T04E housing won't clear on a bottom mount config anyway, will it??????
themadscientist
well the HKS kit top mounts the T04E so you could be right.
Trike
hrmm... good point.. what would be the most affordable way to get around 300whp.. i figure i had this spare turbo lying around.. maybe just by getting a manifold would be a good route, but i don't want to have to make a downpipe for it.
GraySilvia
You could buy the hotshot header enjuku sells. It's top mount and set for external wastegate, and comes with the DP and dump tube. Not the most affordable route, but if you're set on using that turbo...
