What does the orange cord on top of transmission connect to?
jq_s13
Car: 1993 240sx ka24de
stock 93 ka24de and transmission. Doing a clutch job and a freind disconnected the thick orange cord coming from the top of the transmission and cant remember where it goes. Any suggestions???
ChoyLiFut240
Car: 1991 240sx
it really depends on where it was removed from. Is it still on the transmission itself? Or totally disconnected? It attaches to a little nipple on the transmission bellhouse. Or if it wasn't disconnected there, there's also one end that has a metal rectangular piece that has a hole at the end of the metal. That's supposed to be lined up with the top hole in the bellhouse when you're bolting the transmission back up to the engine.
Fireplug
Car: '93 240sx (Built SR20, PT67)
jq_s13 wrote:stock 93 ka24de and transmission. Doing a clutch job and a freind disconnected the thick orange cord coming from the top of the transmission and cant remember where it goes. Any suggestions???
It's your vent tube. The actual vent is supposed to sit at the top bolt of the bellhousing, but you can place it where the starter bolt is if that's easier for you.
AmoebAssassin
Car: 1991 Base fastback 5spd, black
I'd suggest not to place it by the starter bolts. I did that during my SR swap, and when my starter failed that vent tube u-bend made getting the bolts out a pain in the ***. Put it somewhere where it's tucked away and can't get in your way.
