Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Sat May 17, 2008 7:57 am
If you're talking about the self diagnostic you run yourself with the trip meter on the dash... the FSM will tell you what they mean. Start reading around page AT-43. Be sure to run the test a couple of times to see if any codes disappear (specifically the D code).
3 - Throttle Position Sensor circuit is shorted or open.
A - Turbine Revolution Sensor circuit is shorted or open.
D - Battery power is low. Common, and tends to disappear after a reset.
Heath
