twistedsymphony »
https://forums.nicoclub.com/twistedsymphony-u62853.html
Tue May 27, 2008 9:24 am
Possible Amp Connections:-Power-Ground-Amp Turn on (AKA "Remote Wire")-Pre-Amp Inputs (typically RCA Connections)-Speaker Outputs (typically screw clamps)
I've never seen an amp with much more than that unless there was some special feature to integrate it with other products from the same manufacturer.
If I had to guess P.CON is the Remote Wire... If you don't know what this does basically it is the on-off switch for the amp and controlled by your head unit so that the amp only turns on when your head unit is on to save power and increase it's lifespan.
