Haitian_King wrote:One thing I've never been quite clear on is: Does the plenum need to be removed to ohm the injectors?
The purists will tell you that the plenum must be removed to accurately ohm the injectors (and KS) but ohming at the connector will get you darn close. If you got a 0 reading you would have to suspect a problem with the harness (open injector harness code?).
It takes about 5 minutes to ohm the FI and KS and the best part is it's an easy DIY and it's free. The connectors you're looking for will be at the passenger side end of the plenum almost on top of the valve cover- you can't miss 'em and you do not have to remove the plenum.
