What Does Oil Weight #s Mean?
rico05
Car: 1992 RMS13 w/ CA18DET
I am getting the usual timing chain click, and I want to run heavier oil. Currently, I put in 10W-30 and I get the clicking. What I was wondering is what the numbers mean, and what would be a heavier oil to run? 10W-40? 20W-40? Thanks!
Rex
Car: None
I'm sure Fred will weigh-in (pun intended) with his wealth of knowledge of things pretol based, but until then..
Here's a great thread with a link within that goes to another great post with another link within.
<happy reading>
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
The numbers are the weight when cold and when hot...
For instance, when cold, a 10w30 has a viscosity of a 10 weight oil, and a viscosity of a 30 weight oil when hot...
Basically, youll probably want to run a 10w40, which acts thicker when its at operating temps.....
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
i started running valvoline synthetic (synpower i think) 10W30, and most of my engine noise (minus the timing chain ) has gone away. Some oil is starting to leak out between some of the engine gaskets, but it's not much at all... and my engine runs 10x better over all
PalmerWMD
Car: 2004 350Z
rex:
Good job on those links.
Nothing to add.
Fred...:)
MaineExport
Car: 95 Nissan 240SX FAL fans AEM intake Hot Shot header Apexi N1 dual Exhaust VLSD ABS NX 50 shot
The timing chain problem will not be fixed with a heavier oil. It won't be fixed by oil at all.
hudy
Car: 1991 240SX SE Hatch
I'm pretty sure "W" means "winter". And like Doc said to Marty "Weight has nothing to do with it." It is thickness that is the issue here. See this link to valvoline. http://www.valvoline.com/carca...101ovMaybe that page can answer some of your questions as well.
