The question is what weight will the tire support at what temperatire/speed and still pass the explosion test brand new?
If one assumes that the hot temperature is 30-50F warm then the safe psi is 3-5-8 psi greater than the max cold psi.
The next question is what is the REAL LOAD vs the MAXIMUM LOAD.......the smaller the real load, the smaller will be the slipangle.
I always assume the graph will be linear at least above 30 psi. 31/44= 70% of max load x 1521= 1071.......pretty close to the static weight on an unloaded Q front sitting still.But when you add 2 [180lb] front passengers it goes to 1251 pounds or 82.3% of max load ..............36 psi? When you do an ABS full brake 70% [4300x 0.7/2=1505 pounds of weight is on each tire for 3-5 seconds..........would require 43.5 psi]
Obviously 44 lbs cold is too much and 29 psi is too little.......what is the average load on the tire with the typical passenger load.
The real question is how much safety factor your current tires have compared to the oem Michelin Sport XGTV. How real is the 1521 pounds at 44 psi...................how many minutes will the tire take to explode and at what temperature and camber.
"More recent data provided by Goodyear indicate that fuel efficiency is reduced by one percent for every 2.96 psi of under-inflation. (26) ........from
http://www.nhtsa.dot.gov/cars/...N_23_
http://www.aiam.org/main_pre_det.asp?PR ... ko...c.pdf
