What does LSD stand for?
M3thod_Man
anybody?
ride4lame
limited slip differential
Guffed
Car: cars and girls...What else is there??
ladies suck d*ck
Mr1der
lips sucking dlck!
M3thod_Man
what exactly does limited slip dO? has something to do with transmission and gears i think but from there im clueless... and is it recommended for NA modding?
Nathan
Run a search for limited slip, viscous limited slip, lsd, and vlsd. That should learn ya just about whatever you need. Here's the SHORT synopsis: limited slip allows the power to be transferred through BOTH rear drive wheels instead of just one. It has to do with the differential. Yes, it's one of the best upgrades you can do.
nnkfws333
Car: 2004 Infiniti G35 and a 1989 Nissan 240SX
You should try using the search button or I did it for you:
http://auto.howstuffworks.com/differential.htm
SloMoe
Car: Fast Cars, Music, Girls
It biases torque between both drive wheels. How they work, depends on their design, but the most common clutch type has loaded clutch packs between the spider gears on each axle. When one axle starts to spin faster (wheelspin) friction from the clutches causes the other to play catch-up and transfer torque to the wheel traveling slower. The biggest advantage of a limited slip differential is turning under hard acceleration, when the cars weight is shifted to the outside wheel it causes the inside wheel to lose traction and start spinning. A LSD will help transfer torque to the outside wheel that has better traction.
Holisticbeatz
LySergic acid Diethylamide
WingsNThangs
Car: 91 240SX
M3thod_Man
still have questions = (. Do all 240's come with limited slips? and since the car is rwd, why would you need the vlsd? because of superhicas? superhicas only engages at higher speeds i think, unsure how it works, but its all wheel drive at higher speeds i think... is it necessary/helpful to get a vlsd?
M3thod_Man
hmm i just read hicas comes with VLSD... do other 240s come with just LSD? Seems i answered my own question in like 2 mins lol
jpirtle2
Holisticbeatz wrote:LySergic acid Diethylamide
that's funny, cause I just learned it meant that when I had to do a report on psycoactive drugs in my Psychology class
SloMoe
Super Hicas is Nissan's fancy name for four-wheel-steering, not four-wheel-drive. The reason you would want an VLSD (a type of LSD) is to (somewhat) evenly distribute power to both drive wheel, instead of the wheel with the least ammount of traction, like and open differential would. And it doesnt matter if its RWD, FWD or AWD, if you turn a corner under acceleration with a car equipped with an open differential (no LSD) the inside wheel is going to spin because power is transferred to the path of least resistance, because most of the weight of the car is shifted to the outside wheel in a turn. Ideally in a car equipped with an LSD of some sort either the wheels wont lose traction in a turn or both wheels will lose traction because the LSD biases the torque more evenley to both wheels.
Mr1der
I blame the government for trying to make a super soldier.
isn't stricnine(sp?) used in lsd as well?
M3thod_Man
Ok i didn't mean to say hicas has all wheel drive i meant steering just came out wrong... I thought VLSD is only for cars with AWD. I still do not understand why you would want a VLSD in a RWD car... LSD takes care of the evening out power in both your rear wheels already... ugh so confused
SloMoe
Thats an old myth, strychnine is neither used in the synthesis, produced by the synthesis, or a possible contaminant of the synthesis of Lysergic acid Diethylamide.
SloMoe
VLSD is just a type of Limited slip differential. The V stands for viscous coupling. Each axle is attached to the viscous coupling unit in the center of the differential. Inside this coupling unit there are two plates, one attached to each axle. The coupling is filled with a fluid that thickens when the 2 plates, spinning at different speeds, cause friction. When this fluid thickens it helps hold the axles together limiting wheelspin. There are a few common types of LSDs, one being Viscous Limited Slip, then theres clutch type, and helical.
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
thats my favorite form of LSD. 300 micrograms please...
IvoryJ30t
Mr1der wrote:I blame the government for trying to make a super soldier.
nope, as someone else said, its a myth.
IvoryJ30t
M3thod_Man wrote:Ok i didn't mean to say hicas has all wheel drive i meant steering just came out wrong... I thought VLSD is only for cars with AWD. I still do not understand why you would want a VLSD in a RWD car... LSD takes care of the evening out power in both your rear wheels already... ugh so confused
ok, vlsd is just a form of lsd. in an awd car a lsd is needed in the center diff [at least, in some form] and also most awd cars also have one in the rear as well. basically it just forces both wheels [or the front and rear] to spin at the same speed. an open differential transfers power to the wheel with the least traction.
if your stuck in the mud with an open diff [or doing a burnout] only one wheel will spin. if you have a lsd, both wheels will spin. thats why if an awd car didnt have any form of lsd at all, one wheel losing traction will render the whole system useless.
crzycav86
Car: 93 Nissan 240SX KAT
Go read that article from howstuffworks.com(someone posted it above). Its very helpful
deftdrummer
Car: cars, drums, music, technology
this has probably been discussed at least 500235 times in depth
SloMoe
IvoryJ30t wrote:if your stuck in the mud with an open diff [or doing a burnout] only one wheel will spin. if you have a lsd, both wheels will spin. thats why if an awd car didnt have any form of lsd at all, one wheel losing traction will render the whole system useless.
Not all LSDs function this way, some require a certain torque resistance between the spider gears before it will start limiting the slip, helical limited slip differentials are like this. If you were to put a car equipped with a helical LSD with one wheel on ice and one on concrete, the wheel on ice would spin because there is not enough resistance from the ice to push the pinion gears against the housing and limit the slip. If you know anyone who has a helical type LSD, then put their drive wheels in the air and the transmission in gear. Spin one wheel, notice the other wheel spins the opposite direction just like an open diff. In any clutch type limited slip they would spin the same way. Quaifes (helical LSD) function like an open differential going into a turn and once the resistance torque is reached (which usually isn't much ~20lb-ft) and the pinions start pushing against the differential housing, it starts biasing the torque and limiting wheelspin, providing a smoother transition to oversteer, without it tearing the wheel out of your hands like a clutch type would.
SloMoe
deftdrummer wrote:this has probably been discussed at least 500235 times in depth
Now 500236
M3thod_Man
Which type of LSD does a 93 240 w/ hicas have? Again, is it beneficial to get a different one/type with my car?
Nathan
VISCOUS LIMITED SLIP, it depends on what you want to do with it. Lets not even get into 1 way, 1.5 way, and 2 way lsd's. Just go to the red button at the top right corner of the screen called search and search for what I allready told you too. EVERYTHING you could ever want to know is there man.
M3thod_Man
I did do some searching, but thanks
BuudWeizErr
Lucy in the Sky with Diamonds.
</old people music reference>
Nathan
Such a good song, I need to find my Beatles CD's!
