What does it mean when...
bigfootap
Car: 1991 240sx coupe
You have a high idle (1500) and when you unplug the IACV or the Idle air controller that connects to the IACV and nothing happens? Idle doesn't change or anything after being unplugged.
Sil240
Car: Nissan S13 "The One Cam Wonder"
Tr setting your tps to. 45 or. 48 volts. Make sure your throttle switch is closed electronically
bigfootap
Yeah I've set the TPS to .45 so its good. I think I'm going to try replacing my IACV.
Anyone got a spare?
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
The nissan sentra is the same from like 91 I believe??? $25. Also, make sure the adjustment screw on it is screwed all the way in minus a half turn.
bigfootap
The Sentra one is the same as this? I'm sure you already know but I want to make sure.
bigfootap
Darius wrote:The nissan sentra is the same from like 91 I believe??? $25. Also, make sure the adjustment screw on it is screwed all the way in minus a half turn.
$25 from where?
I can't find anything under $80
240z4u
Car: '95 Nissan 240SX
Do you have power at the solenoid? It may not be defective. Mine doesn't work for some reason either. I just have it screwed down almost all the way. maybe one day I will fix it.
bigfootap
yeah its got power. I took it off to inspect it and I believe its suppose to have a spring inside of it and theres pretty much nothing inside of mine. I think that is the problem.
