what does in and out ?
808fronty
Car: 2001 frontier SE
can someone explain what in and out mean when they talk about safc and stuff.
i want to learn so i can turbo my 01' frontier :)
Gonna need a little more specific info than that... but an SAFC is a shortcut and shouldn't be relied upon for tuning a turbo KA. Ever.
808fronty
Ohhh ok right on thanks for the info on that. =)
Going to research more about tuning a turbo KA before I ask more questions.
But can i reply to you if I have any?
Anyone in this part of the forum should be able to give you good info...
Good luck, and happy reading!
eazye2000
Car: S13 KA-DET
The SAFC goes in between your MAF and your ECU. It tricks the ECU into thinking more, or less air is coming into the motor, and adjusts fuel accordingly.
IN means that you basically want to tell the SAFC what type of MAF you are using. There is a number associated with MAF's that you will use in the IN part of the SAFC.
The OUT means exactly that. You tell the SAFC to OUTput the signal of a certain MAF according to the same chart we used on the IN. This is typically what your ECU wants to see; like the stock MAF number, or if you have a chipped ECU you put in the MAF that it's tuned for in the OUT portion.
Then you go about setting your cylinders, Throttle Position Sensor type, etc.
It sounds harder than it really is. It's really a very simple piece of equipment. The problem is that is adjusts fuel, and not timing; and when you typically add fuel with the SAFC, it starts to advance timing which is bad for a turbo vehicle. So please do some research and make your purchases accordingly.
Any other questions, post up :)
808fronty
alright im gettin' it hahah.
but ummm what brands would you preffer?
ex:GREEDY,AEM,etc.
eazye2000
Car: S13 KA-DET
I think Apex-i is the only one that offers a fuel computer like that. Or at least that's the one that I've only come across.
I had one for sale for the longest time, and it finally sold. I would have hooked you up. They usually go for 100-150 most of the time. Check the classifieds and see what you can come up with.
I'm sure there are other companies that make them, I just don't know who they are or how to use them.
neverlift
a few other make them but damn they cost alot. Basically you can almost go stand alone or nistune for what it cost new..
I enjoyed my afc setup but a rom tune is moar better, turn key every time is a nice feature.
808fronty
awww man a little to late.lol
but thanks guys i'll check in on that Apex-i brand.
ohh wait another few q's
what is nistune, standalone and rom?
sry total noob at this tuning/management stuff.
Chris28
Car: 92 s13 KA-T
Nistune, standalone, and ROM are the three reliable forms of engine management for a KA. A standalone replaces your ECU entirely, it can control pretty much any aspect of the engine. This is the most expensive option since most standalone computers cost a lot and you have to have it tuned by someone.
A ROM tune is when your stock ecu has been "chipped." Your ecu is given a new set of timing and fuel maps that work with boost. This is the cheapest option at around $300-$500 dollars, as well as the easiest option. You simply send your ecu off and when it comes back you plug it back in and it will work with your larger injectors/larger mafs.
Nistune is kind of a combination of both standalone engine management and a ROM tune. You still use your stock ecu, but it has been modified so that all of the parameters can be altered. You can sometimes find tunes that you can load onto a Nistune ecu that will work with your setup, but usually you have to pay someone to tune it on the dyno.
I prefer a simple ROM tune just because of it's ease and how affordable it is.
808fronty
thanks dude! =)
but will the computer upgrade from 4x4parts.com work?
it says that you send in your ecu with details about the upgrades you have put on. so im guessing thats a ROM tune? lol
