Second Shadow »
https://forums.nicoclub.com/second-shadow-u4629.html
Wed Apr 14, 2010 10:06 pm
if you can find a vented gas cap(which I haven't ever looked for but I can't imagine being hard to find), you can just plug the hole. if you can't you need to leave it open. the vapor inside a totally sealed tank can expanded in the heat (summer is coming) and cause the tank to be put under pressure, which may lead to gas leaks. I doubt they would be massive leaks, but you still don't want any.
one other thing, if you find a carbon can you like make sure you hook it up right. there are vacuum diagrams in the FSM that explain how it's supposed to be done. thing is if you hook it up wrong you can do anything from create what the engine/maf will see as a vacuum/boost leak, to pressurizing your gas tank with whatever boost your running.
