nismofly »
https://forums.nicoclub.com/nismofly-u19497.html
Sun Oct 15, 2006 9:38 am
the rears will sit more flush than the fronts because of the sizes you got, the reason i suggested the spacer sizes i did is so theyd sit fairly even
actually now that i think about it you could probably run a 10mm front instead of a 15
any spacer is going to be worse than no spacer, the minimal differences were talking in material (1/2 a cm) dont make much of a difference
although bolt ons are much better than sandwich spacers from that standpoint
what kind of tracking are you referring to? circuit stuff? if thats the case youd probably be better getting a set of dedicated track wheels to run just at those times
