Very true! PMQ if you're that cheap get it TIGed. Sand/bead blast it first, take it in. Should be about $15-20, don't tell 'em how much a new one is!Believe me it won't last. Don't heat it up past 380f -it'll get crispy/anneal. It may have already, because ovens are very sloppy heatwise. (they just bracket a temp) When the guy/gal tries to TIG it he/she will know if it got tooooo hot. Then all you have to do is very carefully file the gasket surface flat and use a real thin gasket.elwesso wrote:All I can say is that you will be near suicidal assuming you get it all put back together and it leaks......
I agree with that..... It may last a little while (hour, day, month?) but it wont last as long as it should.. If I cant get you the one from my Q (should by next week) id try and find a used one.....squeefoo wrote:Very true! PMQ if you're that cheap get it TIGed. Sand/bead blast it first, take it in. Should be about $15-20, don't tell 'em how much a new one is!Believe me it won't last. Don't heat it up past 380f -it'll get crispy/anneal. It may have already, because ovens are very sloppy heatwise. (they just bracket a temp) When the guy/gal tries to TIG it he/she will know if it got tooooo hot. Then all you have to do is very carefully file the gasket surface flat and use a real thin gasket.
If it was me I'd find an unbroken one, way too important and hard to get to for cheaping out. The whole car/engine is at risk!
I think the next Darwin Award winner could be from this board.PoorManQ45 wrote:I was making a cake so I figured, "Why not place the part in the oven with the cake."
I put the piece in the oven at the beginning of a 350 pre-heat.I then left the part in the oven for 45 minutes while the cake baked.I took cake out and left the piece in the oven while it cooled off for about 2 hours.
What do you guys think?
maxnix wrote:I think the next Darwin Award winner could be from this board.
http://www.darwinawards.com/
Un-freakin-believable! Must never have crossed the street.
