The Turbonetics T3/T4 is around $765 brand new and Precision is probably cheaper. Would never spend 600 bucks on a used "small" turbo but that´s me.blues14 wrote:i bought an rb25 turbo to upgrade my rb20, but the turbo has a little shaft play. I called a local turbo rebuilder and they said it would run about 600 bucks, but they could 'machine the turbo , install new, steel blades with 'more aggressive angles' and of course replace the seals. they said at 15psi, this rebuilt turbo could potentially support 350+ hp. whether they are blowing smoke up my *** or not is a good question, but If for 600 bucks, I could have a bad*** turbo "brand new" and would bolt up with no mods needed........that would be a great deal. yah....no???
You got a good point, no idea to buy a 500 hp turbo to a 350 hp car car.I just think these turbo´s are pure stone age and most T25 and 28´s got crappy quality. I think you can find a better and more high tech turbo for around 600 USD.blues14 wrote:for a guy like me who is only looking to make maybe 300-350 hp, wouldnt it be a good option? especially since i dont have to fit new lines and have a new down pipe fabbed up? plus it will spool qucker than a large turbo. of course a bigger turbo for 700 bucks may be better for the next guy looking for more power, but your looking at 700 for the turbo, 100 for the new lines, 300-400 for a new downpipe, plus wastegate etc...... but you said a little shaft play is normal?
It's not a bad deal for your goals. Those aftermarket t3/t4's are nice but the cost of buying new oil lines, water lines, ic pipes, adapters, down pipe etc etc.... they all add up.blues14 wrote:i bought an rb25 turbo to upgrade my rb20, but the turbo has a little shaft play. I called a local turbo rebuilder and they said it would run about 600 bucks, but they could 'machine the turbo , install new, steel blades with 'more aggressive angles' and of course replace the seals. they said at 15psi, this rebuilt turbo could potentially support 350+ hp. whether they are blowing smoke up my *** or not is a good question, but If for 600 bucks, I could have a bad*** turbo "brand new" and would bolt up with no mods needed........that would be a great deal. yah....no???
Promise you wont laugh now! It´s stock mounted on Volvo V70R AWD 265 hp. You can but it at your local Volvo dealer or some turbo company.blues14 wrote:hey swedish mike, is that the factory turbo from an eclipse or something usdm?
