What do you think of this 94Q on ebay?
DrewQ45
Car: 1990 Infiniti Q45
It's about 25 miles away from me, however the mileage issue and oil leaks cannot be ignored. What do you think?
http://cgi.ebay.com/ebaymotors...QrdZ1
MattB
Car: 2001 Infiniti I30A
The odometer discrepancy explanation could be true, I've seen stuff like that before. It's very easy to see if that's actually the case by running a carfax. The oil leak would concern me though.
Q45denver
Car: 1995 Infiniti Q45t
1990 Infiniti Q45
1998 Nissan Frontier
Does have a few warning flags like can't read speedometer, odometer shows warning, wife drove for three years with "minimal maintenance".You'd have to look at it.
Q45tech
Contact seller and see if you can get him to bring by T3 [remember new Roswell facility] for a full examination [$75].
Notice the brake light out warning. At worst it only needs a new engine, transmission, diff, heater door, Misc, shocks, suspension, brakes for sure less than $11,000 in repairs............Chicago [injectors].
You cannot/should not bid without a full accurate list/costs of need repairs!
Q451990
Q45tech wrote:At worst it only needs a new engine, transmission, diff...
That would be one way to look at it!
The good news is that you're near the car and can look at. The even better news is the inspection at T3. If the seller balks, it's not a good sign.
Heath
Rex
Car: None
If you're looking for a "return to OEM project", try and find one that's never seen salt/winter. There's rust in the pass rear door sill, which means there's more, as the drivers side usually develops rust first, on the ones I've seen .
DrewQ45
Q45tech wrote:Contact seller and see if you can get him to bring by T3 [remember new Roswell facility] for a full examination [$75].
No way would I bid. I've sent mail to see if he'd allow me to look at it and am waiting for a response.
DrewQ45
Q45denver wrote:Does have a few warning flags like can't read speedometer, odometer shows warning, wife drove for three years with "minimal maintenance".You'd have to look at it.
Yeah, you noticed that too huh?
He proudly stated the "minimal maintenance" as a positive attribute "wooh...this car is trouble free".... then when it breaks down from lack of maintenance, they're ready to sell.
DrewQ45
Seller's reply...
"The transmission leaks maybe a quart every 2 weeks. The power steering less than that, and the engine started leaking more in the last month or so. Maybe 2 quarts every week or so. "
96Qowner
Car: 1996 Q45
LOL! Sheesh, a quart every two weeks??? Same with the transmission???
Vinsanity
Car: honduh 2000 ^_^
actually, he said 2 quarts every week!
I thought my 270k mile daily driver Altima was bad (a qt. every 2 weeks, as a matter of fact), but DAMN!
DrewQ45
Yeah, that would kill my pristine driveway...and I am trying to sell my house.
Rex
Car: None
I had a Vega like that one time ... Fill the oil, check the gas. Oh it used alot of oil, ALOT.
I'm gonna think you're apssing ont hat Q.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Why low mileage, well maintained rust free G50 command so much.
KBB and others are irrelevant for cars in that condition. You will not make money buying one, but you may save some.
breaksr
Drew, don't do it. It's got rust in the weld spot at the rear quarter panel (below rear passenger door). Mine is rusting there and where the rear bumper meets the rear panel on the other side. Almost bought this car just to swap out parts so I wouldn't have the rust situation:http://cgi.ebay.com/ebaymotors...%3AIT
DrewQ45
breaksr wrote:Drew, don't do it. It's got rust in the weld spot at the rear quarter panel (below rear passenger door). Mine is rusting there and where the rear bumper meets the rear panel on the other side. Almost bought this car just to swap out parts so I wouldn't have the rust situation:http://cgi.ebay.com/ebaymotors...%3AIT
That's a common area for rust with most G50s.... although it seems to be excessive in this case. It's the other things that concern me. I may take a look at it just for kicks though. I'm really curious about the oil leaks.
..Drew...
LOL, I had a 929 with a bad valve cover gasket and leaking rear main seal (oil leaks are common the early Mazda JE V6). During one round trip commute, which was a total of 35 miles at 65mph, I'd have to add a quart. Thank goodness for Autozone and their el cheapo Valucraft 10w30.
My '90 Q had its rear main seal done at one point.
redmanfx
Car: 92 Q45a
How about a 92 Nissan Sentra that drank a qrt of oil every 5 days or so. I had to park it at the end of the lot where it would pool up and not get noticed as much. I had to park at different spots at work so no one knew it was my car leaving those awful puddles. Talking about how good a new car felt....
red
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Honestly that Q doesnt look bad... About average to me..... At least its clean minus the rust, which shouldnt be TOO hard to fix.
Q45tech
We just bought a pristine interior/exterior 96 Q for $500 oil light on, rattles and sludged with 129,000 miles this one will be an experiment. We are going to pull the engine out and see if we can save it.
We need Gerbles with brushes and mining lights.........where did I read about oil eating germs?
We tried about 4 years ago on a similar 96, welded a trap door to daily clean the oil pickup with seals and screws on oil pan.........it got traded as a down payment for a new Toyota Pickup.
I've owned a few cars with odo discrepancies, thanks to DOT/DOR mistakes. As a result, they weren't backed by the Carfax guarantee. Its especially common on older Fords where the odo only had five digits.
The oil leak is a point of concern. The rest is the typical Nissan leakage thats easily repaired with new hoses. I'd take it for $1700-$1950.
DrewQ45
Here's another 94'. I feel like I'm surfin for Nico p0rn. She's got an injector issue... maybe a nipple or two clogged?
So beautiful... as you can tell, I have an affinity for red-heads.... Check out this a** shot!
front shot....
Owner's ramblings....
"Vehicle Description
I purchased my baby new on February 23, 1994. It came to $47,388.60 out the door. It's always been garaged and never in an accident. No rust anywhere. In addition to every conceivable option and power-everything (that works), this Infiniti has factory wheels, not hubcaps. There are two remote key units and two modifications I made the week after I bought the car. One is an ignition cut-off switch on the console, to make the car a lot harder to steal when parking in a shopping center (it has an alarm too), the second is a built-in top-of-the-line Uniden radar/laser detector. The control unit is right next to the steering wheel, the radar sensing unit is hidden up front near the radiator, the laser sensing unit is not noticeable by the rear view mirror. What makes a Q-45T different than a Q-45? The "touring" package consists of a sportier suspension and a tighter steering ratio. Add the traction control and this car is a lot more fun to drive than other luxury limousines. Yes, the air conditioner is perfect, yes the Bose audio system is perfect, yes, electric memory seats and everything else works perfectly. Even the big round clock keeps perfect time. The tires have better than 50% life left (although I'm not sure how you determine that). OK, so why am I selling? First, I have 7 (count 'em 7) other cars and my wife says, "enough already" (we only have a 6 car garage for 8 cars). Second, I'm 63, my wife is the little old lady from Pasadena (actually, a retired college professor), but I never let her drive it anyway. I just don't drive it much since I retired. Third (and please read this careully), it has 2 problems and a VERY minor third problem".....
...yadda yadda yadda and so on
elwesso
2007 BMW M Coupe
Man, red over BLACK 94 Q45t... IMO it doesnt get more choice than that.
Rex
Car: None
That looks like a much better candidate, assuming you know there's maint that needs doing and pay accordingly.
96Qowner
Car: 1996 Q45
Now, THAT'S a beauty!
"Finally, I have all the manuals, sales brochures, books and beautiful picture portfolios that came with the car PLUS every invoice and all maintenance records from Day #1 ...
My god, it went for $2499????
DrewQ45
Rex wrote:That looks like a much better candidate, assuming you know there's maint that needs doing and pay accordingly.
Yeah...it was way up there in CT. Can't blame the purchaser for using buy it now. Seems worth it to me. I'm not really actively shopping for a Q, but I'll grab a steal if I see one yah know?
Rex
Car: None
DrewQ45 wrote:... I'm not really actively shopping for a Q, but I'll grab a steal if I see one yah know?
Yes, yes I do .
ProfessorMike
Car: 1991 INFINITI G20
Can't believe you're still talking about these cars, it's been a couple of years since I was on this forum, some of you I recognize from when it started.
Vinsanity
I wonder why that seller had his radar detector built-in all sneaky-like. it's not like they're illegal (AFAIK in his state), and probably took more effort (money) than it's worth.
now a built-in (hidden) radar/laser JAMMER...that would be marvelously devious
Crimson.BBS.
I'M IN LUST!
