What do you think of the CVT transmission
ruatynail
Car: 08 Altima sedan
I think it's pretty cool but in drive mode at a light pedal and low speeds it seems to lug the car. Anyone else experience this?
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
Maybe im just a moron.. but i dont understand what you are saying...
In drive.. (i follow)
"at a light pedal"- ???
"lug the car" - ???
squik
Car: Altima Coupe 3.5se
I really like mine. For the record I can drive manual very well, I just decided that for my daily driver I didnt want to...
I think he means to say is that at low speeds the pedal seems a bit touchy, if I am not careful about only pressing it a little the car seems to want to take off.
ruatynail
under light accelleraion it sems that transmission nees to move to a lower gear. at this point when more pedal is given, the car launches. this is at low speeds
AltimaJoe
Car: 2008 Nissan Altima Coupe 2.5S Premium Package
I know what you're talking about and I noticed it with my CVT as well. Usually anywhere that my speed is less than 30 m.p.h. the car will act almost like it would if you had a manual transmission and were cruising at 30 in 5th gear. So usually around 30 or lower the RPMs will be at or lower than 1k. It's annoying, but I just pop it into manual mode and downshift once or twice and it smooths right out.
leeroy300
Car: Altima Coupe 3.5 SE CVT , niagra gray
the 3.5 does the same thing doesnt shift down like we are used to . just holds the gear longer before things happen sort of .you can hold throttle position and hold a steady rpm under 3000 rpm's and the speed will climb in speed just doesn't feel torquey
Modified by leeroy300 at 1:28 PM 12/21/2007
