portisroads wrote:Thanks, I'm not really worried about top end. I really appreciate the help.
Since you posted that turbo specifically, I assume that you've bought it already or can get it for a good deal. So if that is the turbo you are going to go with I think you'll like the .48 A/R turbine housing over the .63 A/R housing for quicker spool up. You can try Turbonetics for that housing if you'd like to try it. Like I said an equal length manifold should further help spool up because of the well balance runner flow into the turbine.
Your fuel system is the next concern. New injectors are a must. Like Nismo_Freak said, the stock 370cc injectors will go to about 260whp (I didn't know that), but you should be past that with all these mods. The T04S 60-trim compressor is going to flow a much larger volume of air at 10psi than the stock T25/T28's could ever hope to. If you do ever boost past 10psi, on purpose or accident, you going to detonate and kill the engine unless you do some fuel upgrades. If you don't want to go stand alone you should at minimum get a fuel controller of somekind; S-AFC, JWT ECU, etc. Also an adjustable fuel regulator would be nice with a new fuel rail to feed the new injectors. Once you get the fuel system dialed in you should notice further improved spool up.
I would definitely consider Nismo_Freak's other recommendations as well. The car will be a real killer when you get done with it! :thumbup
