what do you rev to?
DRIFTEADOR
and whats the setup (valvetrain/cams/im etc.)?
Structure240sx
drviing ont he street i hardly get past 4500rpms before i shift. by then im moving too fast. racing i try to shift between 6500 and 7000rpms. i have a built bottom end with a stock head jsut a valve job.
my torque starts to drop off after it peaks prolly cuz of my stock cams. it still pulls hard tho
scruffy63
Car: my nissan 240sx
hey structure I have a question approximately how much do you have in your current motor how much for the build up and turbo kit. not just parts either how much did you pay at the machine shop.
not trying to jack the thread so I shift around 4 or 5 in regular driving and somewhere between 6000-6200 when racing. i'm pretty much stock though.
crzycav86
Car: 93 Nissan 240SX KAT
Damn.. you guys drive your cars hard..
I shift at 2.5-3k... just enough to get into the next gear.
When I drive hard, I might take it up to 6.5k
Structure240sx
i figured he meant driving hardER
normal street driving i shift the same as you
scruffy- AIM me at structure240sx if you want to know details
DRIFTEADOR
stock redline is 7k, right? would you feel comfortable taking it higher provided the cams were making power?
crzycav86
Well, you'd need an ecu retune to eliminate that rev limiter..
4felix20
Car: Emerald Blue S14
i always shift right around 3k. that's about the time my t3 starts to spool and i try to stay out of boost as much as i can...it's hard though.
574-240sx
Car: Nissans, Toyotas, Subaru
Driving normally I shift around 2200 to 2500 maybe sooner. Yes it really hard to keep off the boost. On the street playing around with the locals I shift at about 6500 I will hold it longer pending who I'm racing. I shift at 6500 at the drag strip. Drifting who cares, I don't look at the rpms, thats what a rev limiters for.
240marcuSX
Car: E34 525i
E46 M3
wheres the limiter? but thats only when racing, right before braking, when upshifting wouldnt make much since.
other than that, 3-3500
daniel240
Car: cars/motocross
when i get on it hard in 1st gear, its hard to shift to 2nd before it hits the rev limiter. the turbo just spools so fast and the tires break loose when boost hits and by then its at redline. im always bouncing off the rev limiter in 1st gear even when i try to shift before i hit it. but generally i try to shift between 6k and 6.5k.
95_240sx
Car: My baby (car)
Wow, you guys are a bunch of sissies. I run my car out to like 4500 on the street, thats where my boost comes on full on low boost. But then racing I usually wind it out to 7500ish. It only takes me a minute to change the MSD RPM Pill or the Revlimiter inside the ECU. My lowboost tune revvy is at 6500rpm and the high is at 7800. I do however love the sound my the MSD's revvy on boost.
Rick
95_240sx
Car: My baby (car)
Oh yes, I have a fully built motor. Crower rods and Wiseco pistons, balanced, I have a Port and Polished head, but the only think stock in my valvetrain are the valves...the other things are not going to be divulged
Rick
nissanfanatic
Car: 1992 Nissan 240sx SE
If I'm in town, I'll shift at like 2-2.5. On the open road, I'll shift around 3k. Racing, it really depends. I mostly listen for when to shift, but it is about 6.5k. All stock engine. 135K miles.
ossBASHA
Why are people turboing their cars when they don't even get into boost most of the time?
4felix20
cause it's my daily driver ossbasha. boost isn't needed every single time i drive somewhere.
DRIFTEADOR
Quote »Wow, you guys are a bunch of sissies. I run my car out to like 4500 on the street, thats where my boost comes on full on low boost. But then racing I usually wind it out to 7500ish. It only takes me a minute to change the MSD RPM Pill or the Revlimiter inside the ECU. My lowboost tune revvy is at 6500rpm and the high is at 7800. I do however love the sound my the MSD's revvy on boost. [/quote]thats more like it
Quote »Why are people turboing their cars when they don't even get into boost most of the time? [/quote]because most of these cars being turboed are daily drivers. replacing motors often isnt very convenient
toki
gas milage...thats why...
ossBASHA
toki wrote:gas milage...thats why...
True... but, I wouldn't be able to lose out on all the fun
Nismo_Freak
Car: 89 Nissan 240SX
When you get a boosted car, you drive the piss out of it. Then things start to break, or you just get used to it and drive it like a normal car.
At least thats my experience.
nissanfanatic
The po-po's don't like boost as much as we do either. Traction on the street isn't very good so you know...
I boost probably 1-2 times every 1 or 2 days. I boosted twice yesterday so YAY!!!
574-240sx
Samething for me too. I drove the piss out of it until it wasn't fun changing out parts in the middle of the night week after week.
Drift Machine
Car: 1991 KA-T 240sx
Nismo_Freak wrote:When you get a boosted car, you drive the piss out of it. Then things start to break, or you just get used to it and drive it like a normal car.
Very true, something I think probably applies to most people who boost their cars. For me it was a combonation of both, I got tired of fixing **** everyday. Along with it not feeling very fast anymore.
In town I shift aroudn 3000, but if I'm boosting I shift around 6500.
Florida240sx
I'm on a stock engine and usually go to 4-4500. racing usually only go up to 6500 in 1st and 2nd by then I'm ahead and go straight to 5th and laugh. Can't wait till I'm turboed.
andrave
Car: 1989 Nissan 240SX Coupe
stock everything, 7k rev cut, shift at 5500
DRIFTEADOR
shift at 5.5k when racing? even if the motor's torque output decreased as rpm rised, wouldnt the multiplication in lower gears make it worth to shift later?
ArticDragon192
Car: 91 Z32 2+2
Stock engine, daily driving shifts at 2.5k-3k. Pushing it I shift at 6.5k at the latest or once I'm going fast enough I shift to the high possible gear.
jmauld
Internally, the engine is stock. I take it to redline everytime I shift, when autocrossing.
After my dyno, I did the math and the only gear that made since to shift before redline was 4th->5th.
andrave
I bang the revcut occasionaly on the 1-2 but past that I usually dont' exceed 6k even when racing, though sometimes I make a 4th gear exception...lolnot very often though
