Red-KAT wrote:at 4psi you should be fine with stock injectors... And I think the MAF is good to 8-9psi.
Uhhh, not quite.
A 4psi on a t3 is not the same air flow as 4psi on a T3/T04e.
The stock injectors will work at 4psi, but that's pushing it. If you wanna keep the injectors, use a rising rate fuel psi regulator, otherwise known as an FMU (fuel management unit). You'll want a 12:1 ratio on the FMU. This way, you use no electronic tuning. Also, the stock MAF is good up to around 240whp. You won't be seeing those numbers on a 4psi setup, so don't bother messing with it.
If you choose to go with electronic tuning, I'd go ahead and step up to 370cc injectors. If you wanna push more than the 220-240whp range, I wouldn't recommend just an FMU, as you'll want some finer tuning capabilities. Also, I don't recommend pushing the stock injectors that hard.
Have fun!
