What do you guys use for exhaust flex?
PMan_S13
Car: Building car -> breaking car -> fixing car -> start over
I'm putting together my own 3" exhuast from the turbo back. No one around here has the balls to make one, so I was somewhat forced to make at least the downpipe all on my own.
Anyway, I have the downpipe all finished and I pretty well have the rest of the exhaust back to the muffler finished. But so far it is all straight pipe. It has no flex whatsoever besides what the pipe (and my gorilla welds) allow.
I wanted to use 3" flex pipe to be welded in right after the downpipe. But no one around here carries the stuff. Speedy muffler can get it for 105 plus shipping for a 10" section. (Yeah, the're out of their freakin' minds) If someone knows an online retailer that would be sweet.. I can't find anything. Ebay has some for 34 plus 15 shipped.
Does anyone have some pointers on what I can use to assure my exhuast won't shake itself crazy?
bruinbear714
PMan_S13 wrote:I'm putting together my own 3" exhuast from the turbo back. No one around here has the balls to make one, so I was somewhat forced to make at least the downpipe all on my own.
I'm using the 3" flex section from atpturbo.com.
ziggy682
Car: 1991 240SX Turbo
Flex pipes are generally for front wheel drive cars, because when the engine torques, it will pull and push the exhaust. In a rear wheel drive application, the engine will twist the exhaust, and there should be enough play in the rubber exhaust hangers so you wouldn't need a flex pipe.
I know my S13 didn't have a flex pipe stock, and now I have a custom downpipe, and Apexi N1 exhaust, and it's just fine with no flex pipe.
Soulja
I would rather have a section of flex pipe, than shaking in the exhaust over time causing the welds in my manifold to crack. Anything that you can do to make a tubular manifold last longer, is a good investment in my opinion.
red240ne
Car: mmm...donuts
ebay flex pipe. I personallly don't run flex pipe either tho
PMan_S13
I know they generally are for FWD, just thought it would help me sleep better knowing some of the flexing is done by something deesigned to handle it.
But I suppose you are right about the rubber bushings...
huguetpj
Car: 93 KAT Coupe
Soulja wrote:I would rather have a section of flex pipe, than shaking in the exhaust over time causing the welds in my manifold to crack. Anything that you can do to make a tubular manifold last longer, is a good investment in my opinion.
Well a good manifold with good welds should not crack anywhere.... mine hasn't and I have no flex pipe. I even ran the car up to 1600°F+ EGT while running track a couple of times. Fortunately nothing burned nor failed. I'm pretty confident my mani won't fail me now :pface
Soulja
huguetpj wrote:Well a good manifold with good welds should not crack anywhere.... mine hasn't and I have no flex pipe. I even ran the car up to 1600°F+ EGT while running track a couple of times. Fortunately nothing burned nor failed. I'm pretty confident my mani won't fail me now :pface
alot tubular manifolds will eventually crack, some are know for it more than others. The flex pipe is a cheap peice of insurance, to help with the problem.
huguetpj
Car: 93 KAT Coupe
Soulja wrote:alot tubular manifolds will eventually crack
Not if they are WELL made... and mine was custom made by my muffler shop, no fancy name high price mani here :pface
Quote »The flex pipe is a cheap peice of insurance, to help with the problem. [/quote]
I do agree on that. I just forgot to put that on the last post. But it is not as important as with a FWD car. As someone said, the rubber hangers should be enough.
sil80drifter
Car: 1990 240SX Hatch
http://cgi.ebay.com/ebaymotors...=WDVW
this is what i got for my downpipe (but 2.5" instead of 3"), i am going to build it in right before the cat.
sil80
PMan_S13
I went ahead and just finished welding up the 3" exhaust. Seems to be working fine so far. I've driven it like this all week and put it through it's paces.
Only small issue now is I'm having trouble keeping the bolts holding the downpipe to the turbo tight. I guess I'll have to find some very high temp lock-tite
