heres the current parts list:
KA throttle body
Z32 Maf
Denso 560cc injectors
Nismo FPR
Jun Light weight FW
Spec Stage 2 Clutch
Single piece Steel DS
S15 T28
ACL crank bearings
ACL Rod bearings
NEW rings
Cometic HG
ARP head bolts
ARP rod bolts
ARP FW bolts
Greddy Timing Belt
OEM tensioner bulley
OEM spring clip
OEM Idler pulley
NIStune ECU
KAAZ 2way
complete 3'' exhaust
HKS EVCS
HKS Recirculated BOV
block and head cleaned/decked...
all internals getting a much needed cleaning...
Walboro Fuel pump
also note (if at all matters) :
intake manifold ported to match TB
slight exhaust port
complete deletion of the secondary throttle butterflies (complete system is being removed and holes welded shut)since there already not in use.
New Water pump
New Thermostat
New OEM oil Pump
new seals...EVERYWHERE...lol
New Gaskets...EVERYWHERE...lol
New Bolts...EVERYWHERE...lol
current Gauges:oil temp,oil press, fuel press, water temp, Wide band o2.
new engine and transmission mounts
things im considering doing:
LS coil pack conversion
pretty much im just wondering what you guys think itll do as far dyno...any thing i should consider...not looking to make crazy horsepower...just want to get a ball park figure...sadly the whole thing is still in pieces...but getting work done finally...
um...help!?
