Flows 3100 CFM.. and is pretty slim looking. I'd rather have just one large fan than 2 smalls.. but I'm wondering how efficient it would be for an RB26DETT with a stock radiator?
Any input? Does anyone here run a single fan on their RB?
Postby
Joe »
https://forums.nicoclub.com/joe-u4941.htmlSat Oct 30, 2004 6:12 am
might be a tight squeeze unless you are using mckinney mounts. as fr efficency 3100CFM is more than what i would consider adequate but still not as much airflow as 2 2500ish cfm fans. why dont you want to run 2 fans?
Postby
Nameless EJ6 »
https://forums.nicoclub.com/nameless-ej6-u7239.htmlSat Oct 30, 2004 1:41 pm
Ya I'm using MK mounts.
The reason I want one fan is because it looks clean, and because the area it covers is likely larger than what two small fans would cover. From what it looks like at least...
Postby
hashiriya13 »
https://forums.nicoclub.com/hashiriya13-u4580.htmlMon Nov 01, 2004 7:42 am
You may be able to get it to fit on towards the passenger side of the radiator. I know with the Koyo 3.25" would not work as a puller but you may be able to get it to work with the stock radiator.
Postby
NISMO_RB25 »
https://forums.nicoclub.com/nismo-rb25-u11080.htmlMon Nov 01, 2004 10:20 am
If you are keeping the 240 radiator, the flex-a-lite dual fans can be made to fit really well. I think the model was 220. Anyway those things were awsome and fit really nicely. If it wasn't for the Koyo I would still be using them.
Postby
420_240 »
https://forums.nicoclub.com/420-240-u12832.htmlMon Nov 01, 2004 10:26 am
i'm using the r33 radiator and the FAL 220s as pullers on my car... i had to remove the aluminum shield on the driverside fan cause it was rubbing on a pulley... managed to get a little room out of that
Postby
Nameless EJ6 »
https://forums.nicoclub.com/nameless-ej6-u7239.htmlMon Nov 01, 2004 11:26 am
PROJECTRB240SX wrote:THOSE FANS ARE A RIP OFF.
Back up your info. Have you used one before?
I'm using a stock radiator for my swap with an N1 WP.. I don't really want a thick radiator with the intercooler I'm using. If it doesn't work I'll upgrade.
