what do you guys think of these turbo specs?
emperor_lunchbox
Car: 91 240sx, 96 eclipse spyder, and 96 camaro z28 (For Sale)
.50 A/R, .63 Exhaust, Stage III WheelI don't know what the trim is though.
Here are some pics
emperor_lunchbox
another
emperor_lunchbox
and another
emperor_lunchbox
last one.
Im looking to make 300 HP max. do you guys think this turbo can handle it?if it can around what boost level do you think it will take?Thanks.
Edub1
Car: 89 240sx KA-T
I think there will be a lot of lag with a stage 3 turbine.
I just put mine up on Ebay - it's exactely what you need for a 300HP setup.
http://cgi.ebay.com/ebaymotors...%3AIT
KATwo40
Car: 1993 240sx KA-T
Edub1 wrote:I think there will be a lot of lag with a stage 3 turbine.
I run a T3/T04E with a .63A/R turbine housing and .76 trim (Stg. 3, T-31) turbine wheel. I get full boost by about 3600rpm. Not really all that laggy, IMO.
In all honesty, man, the specs you posted give us nothing. The compressor housing A/R seems fine, but what are the specs on the wheel? That's the important determining factor in efficiency and such. Find out more info if you can.
Also, I think the best thing you could buy is Edub's turbo. It's a freshly rebuilt (0 miles) T3/T04E. It's a good solid unit, not some aftermarket turd.
emperor_lunchbox
edub:I looked at your turbo, I noticed that it has a stage 1 wheel. what is the difference between the stg. 1 and stg. 3?From what I read the 50 trim with stg. 3 is the turbo of choice.
MarkEmark
Car: fully-built '95 240sx KA-T
Stage III turbine wheels have a larger diameter than a stage I wheel for the same a/r turbine housing, so if the a/r is to remain consistent on the turbine, physically the turbine would be larger with a stage III wheel versus stage I.
And I don't think .63 a/r turbine with a stage III wheel will be laggy at all...IIRC, it's what fiznat was using on his KA-T and he loved it...it's also what I'll be using, once the damn thing arrives...
Chezedik
Car: 1991 Nissan 240sx
Agreed, but go with the Garrett not the knock-off. Also, I have the flange for sale whenever you are ready to start making your DP.
WDRacing
I also ran the T3/T)4E 50 trim with a .63 AR exhaust housing and stg III wheel. Anyone who thinks that is laggy has never driven a car with actual lag. When I switched over to a full frame T4 with a .81 AR exhaust housing and stgIII wheel, I would have maybe 6 psi will 4800-5000 rpm. Then she would flash spool and jump to 20 psi by 5500-5700.
That is a laggy turbo.
WD
Edub1
Car: 89 240sx KA-T
Well, I've decided to run a T3 super 60 / .63 stage 1 - I understand these are insta-boost.
I think it's safe to say that the stage 1 will spool a bit sooner than the satge 3 though. And, I think the stage 3 guys are into high, 400+ HP where there might be a flow issue. I wouldn't think a guy looking for 300HP would run into flow issues with the satge 1.
Anyway, it's up on ebay so act fast if you want it.
Chezedik
It would depend on if it were .48 or .63, but since the topic is the .63 then I would say there would not be any issue for a lower number like that. In fact, that is what I will be running for about that power level.
