LongBeachCoupe wrote:not an issue as long as you can see
False. I can see better at night with my hi beams on, so would you recommend I drive around with them constantly on? If you were the only car on the road, I'd say knock yourself out. But blasting other drivers with glare is supremely hazardous. AFAIK, 55w HIDs are not legal anywhere in the US. Watch out, I know cops in my area pull over for that sort of thing.
Also, LBC, you make overlays for headlights. Do you know if they have any thermally insulating properties? If so, I'd be really worried about that heat. The best 55w solution for HIDs is probably the philips DL50 bulb (which I highly doubt is in use here as they are fairly rare and pricey). Everything else is basically a 35w bulb with more power thrown at it. This gives it a drastically reduced life as well as putting out insane amounts of heat.
