what do you guys have your agx set on?
turbo2nr
Car: 97 240sx (kouki)
just wonder what is the correct setting for agx depending on spring rate of course.
my setup
tanabe GF210 -spring rate %30+
drop- 1.4f 1.0r
agx front -3agx rear - 6
does that seem right you you guys?
nismofly
Car: 89 Nissan 240SX Hatch
mine are +50% and 1.6, 1.2 drop and set at 3 front 6 rear per Chet's recommendation when he had the same setup...alas i wont be driving the car until May due to winter but i can tell you then
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
I have Sprint springs, lost 3 1/2" of ride height, and have the fronts on 3, rears on 4 with subframe collars and everything else i've got. Can't wait to upgrade to coilovers...
-Dan
kamikazestorm420
mine is set at 3/4 in the front and 7/8 in the rear .
with tein s tech springs
turbo2nr
how much difference does the front and rear feel when going form 3-4 and 6-8?
thanks
skydragoness
Car: 03' 350z Touring 6spd
92' 240sx 60k survivor :)
My daily driving setup:2/front, 4/ rear w/ Suspension Technique springs: 3 front, 2.66 rear
With stiffer tires @ autocrosses: 3/front, 6/ rear. Sometimes depending on the temp and weather I don't need to bump up to 3/6. But this year I plan to run some Bridgestone summer tires, so I'll probably have to.
kamikazestorm420
turbo2nr wrote:how much difference does the front and rear feel when going form 3-4 and 6-8?
thanks
i live in CA and the roads out there aren't pretty. i used to drive it on max settings but it just felt too bumpy at times and i didnt like it.
Dano
Honestly, us telling u won't help much, just give u an idea. Try it out for yourself and see wta works best for u.
-Dan
turbo2nr
i like 3 and 6, maxed out is way to stiff for nyc pot holes.. and 2 and 4 is a little to0 comfortable...
3 and 6 makes it feel nice like a sports car..
my 0.02
