So what do you do with your CA powered vehicle, or what are your plans for it? So list what vehicle your CA powerplant is in and give a brief description of what YOU do!
"Anyway, there is something about engines that calms me down, you know?"float_6969 wrote:I have ADD and I get bored quiet easily.
I do know. It's also the reason that I love my job so much. I own a pool and spa service company (no employee's, just me) and I'm constantly in the same sort of state of mind when I'm fixing a pool or spa issue that I am working on my car. It gives me something to focus on and helps me relax.mdb4879 wrote:"Anyway, there is something about engines that calms me down, you know?"float_6969 wrote:I have ADD and I get bored quiet easily.
Mine's in a KN13 platform (1987 Pulsar)
Pretty much stock, just a little added boost from a worn out wastegate actuator. I think I've got the only CA that makes more torque than horsepower, lol. Anyways, my motor developed a knock while I was letting a friend drive it. So right now I think the plan is to do a stock rebuild with some ARP hardware and a bigger turbo (plus supporting mods of course). Probably gonna shoot for close to 200whp right now until I get ready for my monster build. But I think that one's gonna be a ways down the road the way the way things have been going lately.
Yea, there is a story there. So during the whole HKS turbo kit debacle, I discovered that you can't run a brake booster when you run this kit on a LHD car, there's just no room for it. I discovered this AFTER I had installed the Q45 fronts. So when I converted to manual brakes, I realized that the front-to-rear brake bias on this car with Q45 front's is WAY off. So I went about trying to increase rear braking force. I didn't want to go Z32, but I have done that in the past and didn't want to deal with the headaches associated with the drum brake and the cables. So I found that someone else had discovered that the rear brake caliper bracket from a Z31 (excluding the last couple of years when it went to a vented rotor) will bolt on and the pads fit. The good thing about it is that it's "taller" and moves the caliper out so you can fit a larger diameter rotor. The larger rotor that fits is the Altima rotor. Well sort of any way. It's actually just a little to small, but nobody has found a rotor that fits (and trust me, I've looked). But ultimately, I'm not going to keep it. It's STILL not enough rear brake as my fronts lock up WAY before the rears do (I actually haven't locked up the rears because I didn't want to flat spot my fronts to find out what it would take to lock the rears). I haven't had a chance to drive it since I put the new wheels and tires on though, so I'm hoping the bigger rear tire will help with the bias issue. If not, I'll have to build/design a custom Wilwood setup for the rear.sjbsuperman1425 wrote:Ryan,
you rear brake setup intrigues me a little since my rear <a class="vglnk" title="Link added by VigLink" target="_blank" rel="nofollow" href="http://motors.shop.ebay.com/Car-Truck-P ... span>brake </span><span>pads</span></a> are about gone..
