what do you do in a town like mine (regarding spark plugs)?
stockbee
Car: '95 Zenki-Totaled....Thanks Jeep driver.
'96 Zenki- SR car.....
Well, I've just recently purchased an S14 with a S14 notchtop in it and at intermittent times it will cut out under higher rpm load/boost.
Talked to a few of my friends that have built numerous turbo/v8 240's and they've told me to change the plugs. The ones they recommended while Im running stock boost are exactly what I've found on here: BKR7ES11.
The ONLY issue I'm having is that Oreilly's, Auto Zone, and Advanced Auto Parts tell me they don't carry them, and have never remembered carrying them. Clearly I'm in a pickle when the holy trinity of auto parts stores don't carry what i need.
Where can i get these at ? Anyone that knows please speak up.
I ask good questions
Car: 92 240 SXSE Coupe with SR20DET
Seriously they are being douches. However, get the stock number for that plug and search that way. They should be able to order anything you need. If its made by the manufacturer they carry they can order it. I have a good friend that works at oreilly's. So I know this is true.
stockbee
well it's not exactly that they're being douches or anything of the sort, none of the stores showed that part # when they searched for it, and i looked for it on all of their computers.
i don't know what to do. I'll order on the internet if anyone has a good place they recommend.
the stock number is #2387. Did you do that or look for it using the BKR7ES number? I've got the part number for the iridium plugs in my car if you want the stock number from those?
The stock number for the heat range 7 plug is #6097 for the bkr7e. Try to cross reference that. Should be the same plugs as the 92 sentra se-r runs.
stockbee
thanks for the quick responses, but i had to sleep.
if the last stock number the 6097 one is for the bkr7e, what is the first one for, lol. just a little confused.
stockbee
I've discovered how advanced auto parts looks for things. The stock number.
thanks "i ask good questions". I looked on ngk's site and the bkr7e is a 4644 stock number and advanced has ten of them.
thanks for responding and helping. Perhaps others can use this thread as a help later on.
cody180sx
Car: s14 rb25det fully built 550whp coming soon
i just get the plugs for a 92-94 ser sentra are what ever sentra that has the sr20de same thing. i think that's the right years if it isn't just look for the sentra's that have that motor
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
I think I used NGK iridium's for a 95 toyota mr2 turbo. I know the last # was 11 that means it comes gaped the correct gap for SR20deT's.
