Umm. sort of, but more complicated than that. Alot of the features available on coilovers do not exist for spring/strut setups.dfw240_EE wrote:OK, idiot question: What is the difference between coilovers and a spring and strut setup? Best I can come up with is that coilovers are spring and strut in one single package.
Then I would go with the KYB AGX's and the Eibach sportlines. It will probably look better than mine anyways. My springs are green, and the KYB's are red. Atleast yours will be all red......dfw240_EE wrote:It's an S13 hatch.
I didnt know that you could use those on coilovers that dont come with them. my guess: you would install them under the other spring, directly in contact with the one above? Effect being sort of like a non-linear spring? So that you get a good ride, and then during cornering, you get a bit more roll, but once the helper compresses, you get the stiffness of the co spring? Explain please. thanksDRIFTEADOR wrote:dont mean to steal your thread but this is kinda related to the discussion. Have any of you guys with coilovers tried helper springs to minimize the rough ride? I just got this set of 250lb/in springs that i'll be installing over the weekend
well what do you have on your car as far as camber adjustment? my car is dropped like 1.25-1.5 in the rear, and I dont have rucas or camber bolts or anything, and it is in spec after getting it alignedlrb_2000 wrote:if you get sportlines, which are like 1.8" in back, 2" in front, you're probably going to need some sort of camber adjustment to the front and rear, so you'll have to buy upper pillowball mounts for the front, or camber bolts, and RUCAS for the rear.. mine is dropped on s.techs and they barely got it back into factory specs when it was aligned.. drop is 1.5" in front, 1.2" in front.
I was saying if he got sportlines.. they have a 1.8" rear drop, right? so the camber might be hard to get back.. but I dunno, I just know on my 89 coupe, I had sportlines and the camber was horrible.naed240sx wrote:well what do you have on your car as far as camber adjustment? my car is dropped like 1.25-1.5 in the rear, and I dont have rucas or camber bolts or anything, and it is in spec after getting it aligned
