what do u think!?!
Rekless KA
Car: 96 240sx
i have a 96 ka24det, bottom mount t25 stock boost on it currently, huge front mount innercooler, all 2 1/2 inch piping for innercooler, along with full 2 1/2 inch exhaust, 255 walbro fuel pump, stock injectors, stock maf, tuned with safc. run premium, and use mobil one, my compression is about 160 all the way around, what whp do u think im at right now?
Next question, what maf should i get, i hear the stock ka maf's top out around 190, but i thought i was already higher than that, then what injectors do u recommend getting?, once i get injectors and a maf, my plan is to get my ecu chipped, what whp do u think i will be at then?
S13FX
Car: '69 l20b Dimeski :)
the 190 might be referring to injectors, your maf is good to about 280 give or take more likely take.
As for your wheel hp. If your still running same boost level and tune. It doesn't matter what you get. But you will have to retune for the larger injectors. Then maybe get your self a MBC and turn the boost up a bit. But going past 14psi is creating a blow dryer out of that T25.
And if you have a DOHC, which I assume you do since there is no bottom mount T25 mani for the SOHC unless you make one your self. You will need bikirom or a daughter board of some sort.
Chezedik
Car: 1991 Nissan 240sx
I would guess about 200whp since that is what AtomAnt made (or something like that) in Lawrence, KS. You need to figure out something for fuel and maybe try a bigger turbo unless you are truly satisfied.
