what do u think?
quiksilvia
Car: 95 s14 se
http://cgi.ebay.com/ebaymotors...99636
new cross drilled rotors, set of 4 for 120$
Radian
Let's disscuss cross drilled rotors.I've heard that on the street cross drilled rotors are basicaly a mute point because the heat of the rotor never gets to the point of fading.Also if these were standard rotors that someone "cross drilled" on a drill press, they will be weakend to the point of dangerous. Another reason not to drill yourself is unless the edges of the holes are perfectly flat with the rotor, they will really chew up the pads....Oh...Now that I've expounded reasons not to do it yourself, I look at the auction and see they have counterd every concern already. -warenteed for a year against warpage and cracking? That sounds too goo to be true.Go for it! :fried:
Eklectrick
Car: Photography, Computing
I like this a lot: that just screams reputable.
