what do u guys think 91-94 NISSAN 240SX, KA24DE, 2.4L, DOHC COMPLETE REBUILT LON
nismo_racer
Car: ill be getting a na 300zx soon
this is what it says JIS PART# NLBKA24D291-94 240SX, KA24DE2.4L, DOHC, L4, 16Valves
NEW parts installed:PISTONS, PISTON RINGS,GASKETS AND SEALS,OIL PUMP, MAIN and ROD BEARINGS,TIMING COMPONENT, PISTON RINGS,THRUST WASHERS (if applied) FREEZE PLUGS (if applied)and:Rebuilt cylinder headReconditioned crankshaft*US$400.00 core charge needs to be added on shipping fee.* oh heres the website http://www.jisautoengine.com/n....html
simmode1
Car: Red '95 S14
Lol! Those guys are here in town! I can just go and pick one of those up. I've talked to them and been to their shop. I know a few guys around town who've gotten their rebuilt motors. They seem to work fine, but none of those guys are KA-T yet.
The shop that does my installs said JIS is fine for stock work, but he would referred me elsewhere for engine mods.
I really considered them for a while, but know, I'm like "If I get a motor rebuilt, it's at least gonna have a metal or cometic headgasket and apr studs. At most, forged internals and head work." And JIS don't do all that. I think I'm gonna go to Duron for that.
http://www.katurbo.net/
Spinn3r
Car: 1996 Nissan S14 Zenki T3/T4
nice , thats what i need and cut the BS and screw around with my engine, will this fit 95-98 s? 240sx? or not? where is the one for 95-98 i coulnt find one.
sr20deTsomeday118
Car: 1991 240sx/se coupe
looks great to be completely honest..i was looking around for rebuild kits that went for 1200 bucks..but that was with performance pistons...this has it all done for u!
sr20deTsomeday118
spinner where are u at in chicago?
Spinn3r
around schaumburg area, why?
sr20deTsomeday118 wrote:spinner where are u at in chicago?
480sx
Car: 1996 Pearl White 240sx
Cant beat that price. Figure out what components they use and get back to us, that might be a really good deal.
On a sidenote, Cometic HG's and the like arnt worth the hassle unless your going for 450ish hp or more. Seriously, a fel-pro holds up great and have no extra machining work or processes to make sure they seal and hold. Many more stores about a blown cometic than a blown fel-pro, i can tell you that.
neverlift
cometic=pita imho...
thats a bang up deal, a used ka online cost 3k
local shops(jax florida) want 3k to just do a rebuild. long turned short,if you cannot perform a rebuild yourself, this is pefect!
nismo_racer
it should i dont see why not ill look into it later after i get some sleep lol
nismo_racer
yea im really thinking about it i gotta call them first and ask them a few things
simmode1
Car: Red '95 S14
480sx wrote:On a sidenote, Cometic HG's and the like arnt worth the hassle unless your going for 450ish hp or more. Seriously, a fel-pro holds up great and have no extra machining work or processes to make sure they seal and hold. Many more stores about a blown cometic than a blown fel-pro, i can tell you that.
Thanks! I said 'cometic or metal' cuz I really didn't know which is best and that was really helpful.
You guys got me thinking about buying from JIS again! I wanna slap a JGS kit on it and try to get to 400hp
nismo_racer
yea thats what i want to do is to see if can i just slap a turbo and turn the boost up without anything breaking
simmode1
Car: Red '95 S14
^^^ Hell yeah. With all these 'Stock Block 1,000,000whp' threads running around, I say lets do it!
I just gotta learn more about turboing. Some of the stickies are greek to me. I guess you don't learn some things until you dive in. Right now, I'm dying to know what does "a good tune" mean exactly? I mean, I'm sure no one purposefully wants to do a crappy one...
Modified by simmode1 at 5:01 PM 9/23/2008
PapaSmurf2k3
Site Admin
A "good tune" usually means that the car has spent some time on a Dyno with a wide band O2 hooked up, and a decent tuner tuning the air fuel ratios and timing.
A decent tune would be an ECU that is just generically made for cars with similar setups, meaning they aren't 100% custom. They are usually tuned to be a little safer, but don't extract quite as much HP as a dyno tune.
nismo_racer
a dont feal bad im still learning i even know what turbo i want cuase i said it to my self over and over again lol but its a gt30
nismo_racer
thats gonna suck for me cuase i dont know of any dyno tuning shops in michigan
480sx
You would be a lot cooler with a Borg Warner s258.
Idk im trying to break the Ka-T guys on the idea that the Garrett turbo(specifically the GT-R) is the best option. Fact is, the borg warner extended tip has higher flow rates(more hp per psi of boost), higher HP capability, higher surge lines, and is rebuildable and cheaper than a GT-R turbo. The GT-R turbo spools between 100-250 rpms faster.
Reno
Car: 89 S13, boosted.. RAWR..
Holset h1e or HX40 ?
nismo_racer
really ill have to look into that
