szh »
https://forums.nicoclub.com/szh-u149.html
Sun Apr 15, 2007 9:04 pm
For the M35, Infiniti says that 87 is needed, but but 91 is recommended.
For the M45, Infiniti says that 91 is needed, but that you can get away with less if 91 is unavailable, but make sure to get back to normal later.
So, 93 is probably not needed, but that is what most states in the country have as Premium.
And, yeah, you could perhaps get away with using 89 or 87 in an M45, but this means that the electronics have to compensate for more than the design recommendations.
Plus, you could end up with bad gas ...
Finally, given typical driving miles, and typical gas costs, the difference between filling up with 87 and filling up with 91 is generally about $10 to $15 a month for most people.
Is saving this amount really important to a given M owner? If so, then you probably should have considered getting some other car that was less expensive, with better gas mileage, in the first place!
Z
