I know that it's reached the limitNew2Import wrote:In that video it just reached its limit. It was almost at redline in 5th. Thats all it had.
LOL a CAI and exhaust isn't really going to be all that noticable at that speed. I definitely do not recomend the Injen intake because of the intake pipe size variance from the stock size. Injen claims MR technology to maintain air fuel ratio - which really means that they altered the size of the intake pipe to trick the ecu. That technique is garbage and should never be employed on any nissan. It works by itself, but add an exhaust and you just trashed your A/F ratio and lost a ton of power.Mishooo wrote:
but I notice that from 160 km/h to 200 km/h it's struggle to reach 200 km/h
what I want is to reach from 0 to 200 km/h in less than 20 seconds " 19 is good "ken in az wrote:
Only real way to make the 100mph(160kph) - 125mph(~200kph) noticably faster is to add boost. Remote mount twin T3 turbo's intercooled with an uprev tuned ecu making 500ish hp will make the 100mph - 150mph seem the same as stock 30mph - 80mph
Master - "Conan, what is best in life?"
Conan - "Kill your enemies" "See them driven before you" "And hear the lamentations of the other drivers as you blow by them in your boosted M45"
Can you add a Video clip for your acceleration plzken in az wrote:Well I just went back and wathced the video again and from what I gathered it took that car ~24seconds to reach 200kpm(123ish mph)
I go back to my earlier statement and recomend boost. I don't think that there is any way an exhaust/intake combo will put you to where you want to be under 19seconds.
That being said I'll go out and test this today and see how fast my M is to 125mph and report back.
Oh, and using a translator reading the coments for that video, that M is 100% stock.
OKken in az wrote:Sorry, I stayed in town last night so I couldn't get any runs in. Will try today and get video.
Is it a rule of thumb to add either exhaust or CAI, but NEVER together as it would only result in loss of power?Also what is the typical gain in terms of HP from Stillen cat-back for example? What about from CAI only (w/o exhaust)?M4T5 wrote:Take Ken and myself's advice. Just add a Stillen or Megan full cat-back system and be done with your mods.
I say just don't add the Injen because it is junk....my homeade adds a high flow amsoil nano dry filter and retains the factory MAF sensor piping diameter to keep the calibration the same. The negative about my homemade intake is that it draws in hot underhood temps, which is really only a problem when in traffic or parked in line at the drags that's why I want to add a heat shield otherwise highway speeds the stock cool air duct over the radiator cools things off pretty well.timecurve wrote:
If you have it on there by itself, then just leave it. From what everyone says it works well by itself but looses power when you add an exhaust. so if you aren't adding an exhaust, just leave it on there as it should work just fine.LibJunkie wrote:This post kind of sucks for me. i stumbled literally a day after i instaled the Injen on my M. Any suggestions should I remove and try to find some other sucker that wants. i really have no intentions on installing any after market exhaust any time soon.
M4T5 - I thought you got the Element 114 intake - no? I remember you having a fitment issue with it, did it get worked out or did it get filed in the circular file?M4T5 wrote:throw it in the trash or just send it to me! I'll pay for the shipping to get it off of your hands.Let me know something.
J
