what do these wires go to???
sillbeer10
Car: RPS13
im doing the wiring for my swap, s13 blacktop into a s13 240sx. The SR harness came with the MAF plug cut along with all of the other plugs on the MAF section of the harness cut. i know what to do with the MAF wires but there is a purple/white stripped and a black w/ silver dotted wire that has been cut. Are these wires for power steering? if so what color wires get spliced together on the KA power steering plug? Also there is a blue/yellow stripped wire which has also been cut and i dont know where it goes?
93180sxredtop
Car: 93 240sx sr20det
ECU Pin 26 - Exhaust temp sensor inout (Behind the Cat) - Blue/ Yellow ?????????
sillbeer10
Car: RPS13
so i dont need blue/yellow unlesss i got a gauge??
Tx-Sx-FS
Car: S13 KA-T
hey, i got a s13 sr into a s13...but what wiring is needed for power steering...its not just the pump and hoses??? HELPMY CAR SO FARhttp://forums.nicoclub.com/zerothread?id=114007
daryl337
Car: '90 240sx
If you look closely.. you can see that there is another plug (atleast on my red top SR) That looks identical to the wastegate pressure regulator solenoid... only the wires going to it are purple and (I believe) black... those are for your power steering lines.
sillbeer10
Car: RPS13
i talked to the people at heavy throttle and they said this:
Those are for power steering rpm / idle booster which never does anything so we leave them unconnected. Blue Yellow is AC (not used), look on our FAQ to see how to hook it up using the KA AC wire
