Can anyone tell me what these two connectors under the steering column go to?
I got this chassis in this condition. Trying to figure some of the last wiring issues out.
Thanks!
Thanks! I got a shell with half a body harness, no engine harness, and working thru my first custom wiring job with a USDM 2JZ-GE.PapaSmurf2k3 wrote: ↑Tue Jul 05, 2022 4:29 pmPretty sure the first one is is the OBD1 data link connector. Looks like what I use to connect to my NISTUNE cable. Not sure what the 2nd one is.
This should go a long way toward helping your project in the future;HollywoodJackson wrote: ↑Tue Jul 05, 2022 5:36 pmThanks! I got a shell with half a body harness, no engine harness, and working thru my first custom wiring job with a USDM 2JZ-GE.PapaSmurf2k3 wrote: ↑Tue Jul 05, 2022 4:29 pmPretty sure the first one is is the OBD1 data link connector. Looks like what I use to connect to my NISTUNE cable. Not sure what the 2nd one is.
It's been kicking my butt. LOL
No prob! Those things have been my Bible for my 240s throughout the years. I think I reference the main site-link on about 2/3 of the troubleshooting posts I reply to in Facebook. I try to go further than the typical 'RTFM' reply though. The level of detail in the FSM is wild!PapaSmurf2k3 wrote: ↑Sat Jul 09, 2022 10:39 amThanks!
You're correct, looking at the consult pic you posted, that's what I was thinking about in my head. I haven't looked at it in a while though.
Somehow I forgot the FSM has all those connectors displayed and labeled. Thanks for reminding me!
Thanks to everyone for the information!!!NukeKS14 wrote: ↑Sat Jul 09, 2022 9:14 amThis should go a long way toward helping your project in the future;
I'm guessing this is an S13? Knowing the year of the car would help a lot.
From the FSM link above, I referenced a 1993 240sx. EL section, there is a body wiring harness that shows the location and purpose of every connector on the car (this is true for all of the FSMs.)
HollywoodJackson wrote: ↑Sun Jul 10, 2022 1:58 pmI have been looking at those FSMs for the 1990. But, I'll be totally honest, I'm spoiled by the depth and detail of the 2004 Infiniti/Nissan manuals. The newer manuals have way more detail and much easier to use than the 1990 FSM. All of your answers have helped. Its looking like I can totally ignore these two plugs.
Interesting. The headlamp up/down switch is working with neither of these two plugs in question connected. There may have been some type of weird operation/response from the switch in the dash. I will check again.
Ah! then that 6-connector one is something else, i must've incorrectly identified it.HollywoodJackson wrote: ↑Sun Jul 10, 2022 3:45 pmInteresting. The headlamp up/down switch is working with neither of these two plugs in question connected. There may have been some type of weird operation/response from the switch in the dash. I will check again.
