(1) o2 malfunction, bank 1 sensor 1 This usely means that you fist sensor ( closest to the engine which is the one on the header is bad or not reading properly ) you can pick one up at you local store or go to
http://www.sparkpluge.com
(2) map/baro circuit malfunction check the codes again our cars (240's ) don't have a map sensor ( manifold absolut pressure sensor) they are equiped with maf sensors ( Mass air flow sensor )
(3) map/baro circuit malfunction (Pending) I would check the wires sometimes with age they get britle and the plastice surounding the wire brakes off. causing a malfunktion
Modified by mexicanracer03 at 8:42 PM 3/14/2009
Modified by mexicanracer03 at 8:43 PM 3/14/2009
Modified by mexicanracer03 at 8:44 PM 3/14/2009
