creophus wrote:Ok...so how can I tell exactly? I have the VIN...shouldn't I be able to find out that way? How do I decode it?
No, the VIN won't have options in it. But it you look at the firewall.. on the passenger side there is the vehicle ID plate. It will have an 18 digit code. There are several threads about how to determine if you have VLSD or not. That ID plate code will tell you, but you'll have to do a search of this site to find the meaning of code numbers. I don't feel like doing it right now... it's 2 am here.
TO find out about ABS... look just to the left of that ID plate. If you have an ABS actuator (control unit) then you have ABS. It will have brake lines running through an aluminum block with a 'black-box' computer on top.
Chances are... if you didn't have a fuse in the slot... you don't have ABS. The fuse box will have that slot labeled on every 240 with or without ABS.
