What do i need to know
donttouchthes13
Car: 1993 240sx
Im attempting to put an s14 longblock in an s13 chassis . What has to be changed and will it even work and hook to my transmission? New to the 240 scene
Thanks for any help
seg24life
Car: 1989 240sx Hatch--Daily Driven Build in progress
Need some more info, what year s13 is it? If it is an 89-90 then you definitely need these things: Dual cam gauge cluster, 91-93 throttle cable, and the engine harness and ecu for the dual cam. you will also have to switch your dash plugs, which you can do from watching a video on youtube, i did. give us some more info so we can give you better insight!
seg24life
And all the trannys are the same for the KA's... speed sensors and all plugs work
