What Do i Need to get to Support this in a Stock 350
Nissan 350z / Nissan 370z general community discussion forum
Assassyn
Car: 350z
what ever advice i can get that would be grateful
http://www.rallysportdirect.co....html
i want to put that and run about 700+ to the wheels can the stock block handle this on a day to day basis.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
you'll need a built bottom end for that kind fo power, rods, pistons, oversized headstuds, injected performance I know builds high end motors
rmezz13
Car: Had 2004.5 Nissan 350z
Have 96 f250 and mommas 07 Murano
I would hit up injected performance ^^^ as evildky said... You def will need to build that thing. The stock block can only handle about 400 whp. I would have the block sleeved as well as pistons, rods, studs, and crank. May want to even buy a low compression kit with rods pistons and crank included... Also, COSWORTH sells short blocks in just about any high or low compression ratio you want (8.5:1 - 11:1, i believe)... It would be a lot of work and money for that much power but by all means, very possible.
Return to “350z / 370z Discussion”
