Yes they do.. or maybe my digital cluster is 'special'?jamesblonde82 wrote:...they don't have low washer fluid lights like the analog cluster does
can someone confirm this? maybe the newer ones did, i had one from an 89' model.l0nestar wrote:
Yes, it's a direct swap if you also get sub harness. One thing you have to consider is JDM digital cluster only displays kph. It won't switch back and forth between kph and mph like USDM digital cluster does.TomeiS13Redtop wrote:i would also like to know if the jdm clusters and hud's are a direct swap as i found one for sale??? please anyone respond asap!!!!
Yes, you can use usdm harness.TomeiS13Redtop wrote:it does come with the sub harness but i think one of the plugs is cut off. but i should be able to use a usdm sub harness right?
IDWI I have a whole set for sale if you are interested, I have the cluster, hud and sub harness, email meidwi wrote:Sorry, Moderator, i dont know if this thread belongs to this topics, so, im new in the forum as you can see, and i want to get some kind of help, as the Title says, i want to swap my analog panel to a digital one [Shown on pictures] and by the way, hi my name is Alfred and im from Dominican Republic, THANKS IN ADVANCE ~ ImageShack Album - 4 images
